HI I am using nextcloud snap on Ubuntu 18.04 Server and Snap 24.03 snap 1.
I was able to install nextcloud fine with no issue, however I have had a very slow web ui and server disconnects when trying to operate within nextcloud.
steps
sudo snap install nextcloud
sudo ufw allow http
sudo ufw allow https
sudo nextcloud.enable-https lets-encrypt
fill out the necessary info to register the domain with the SSL cert
port forwarded 443 and 80 as well.
installed nextcloud and now when accessing any part of nextcloud it is very slow or the conection to the subdomain drops out. nextcloud.example.com
I am on ATT 2 Gig Fiber with a BGW320-505 router/modem.
Any advice is appreciated!.
EDIT: This is fixed, had to use a DNS Port Forward Service by ATTs Router and it fixed the issue.
