Nextcloud snap, set pm.max_children
After installation and start of operation, it became necessary to set our own value pm.max_children. But since snap is used, the file with these values ​​is read-only. How can I set my own value for pm.max_children?
Definitely, the possibility of this setting is necessary, since calculations from RAM give values at which the limitation begins to take effect, and no more than half of the RAM is occupied.
4GB:
WARNING: [pool www] server reached max_children setting (78), consider raising it
5GB:
WARNING: [pool www] server reached max_children setting (98), consider raising it
