Sanook
#1
I have installed the Nextcloud SMS app as well as the Android app ownCloud SMS.
The SMSs are transferred from the phone to the NC server correctly.
If i delete some messages by the browser, they will not be deleted on the phone.
Therefore the question: Should the app be a two- or one way synchronisation?
In my opinion it should be a 2 way sync if i look at the config page of the Android app and the description on Google Play Store:
but please correct me if am am wrong.
Thank you!
It is not more than a simple backup at the moment, imho. The word “synchronize” sounds better.
Andy
#3
Have to agree with @anon99252149, it is afaik just a 1-way push to the server
Sanook
#4
That should be mentioned on the Google Play Store IMHO.
As well as on the “Enabled Apps page” of Nextcloud.
@Sanook Marketing …
You can rate the app according to its functions.
Sanook
#6
Bad idea.
What else of Nextcloud is also not working as expected?
Andy
#7
That would need to be mentioned to the app’s developer on the issue tracker.
can nextcloudsms or nextcloud phonesync push the text back to your phone after a restore?
