Hi there,
I have a fresh install of NC 23.04 running on Ubuntu 20.04 with Redis and Memcahed installed. In the “Overview” I get “All Check Passed”… however as I configure settings for various apps… the changes are not being reflected in the NC installation.
Examples:
I set “Dark Breeze” as the default theme, but I get the default NC theme everywhere
I made changes to “Custom Menu” and cleared the cache, however none of changes can be seen.
AppOrder preferences ignored in GUi interface
I used the occ command to run all of the maintenance / repair commands (db, js, etc) but it still seems that appdata isn’t be saved properly.
What should I do?
