I’ve installed Nextcloud in to a container called nextcloud-instance001.local
i’ve copied it as a new instance called nextcloud-instance002.local and have changed the hostname to be nextcloud-instance002.local.
I then stop the 001 instance and start the 002 instance.
When I firefox http://nextcloud-instance002.local it asks me to add this as a trusted domain (as I’ve not setup ssl yet) however when I press the button to add, it looks like it is redirecting to “http://nextcloud-instance002.local/index.php/settings/admin?trustDomain=nextcloud-instance001.local”
What files do I need to edit to change instance in the 002 that are pointing to the 001 instance?
