I’ve been using a Nextcloud Box since its introductory launch. (It’s a pity that no Shenzhen outfit stepped up to take the baton from WD Labs - sad on many fronts, especially the brains at WD Labs but that is another story). I cannot say enough nice things about the solution even though my usage is constrained by only one active user and many, many RPi, Ubuntu and, of course, some Windows boxes - truly a setup & forget solution for my needs.
I keep the box current with quarterly update/upgrade and image backup. Everything works cleanly (as advertised)!
My inquiry is more around the strategic roadmap for the Home user. Is this solution going to be supported for the next few years? (in the event future Raspbian images need tweaks or the user needs a higher capacity hard drive ).
Thanks.
