Hi!
I have been playing with Nextcloud for a while, and I installed it on my VPS few days ago. Everything seems to work perfectly, but the problem starts when I want to install other service - in my case it would be Ampache.
Basic info:
Apache (engine) with HTTPS,
VPS,
Nextcloud beta 13.
What is Ampache?
Ampache is a spotify-like service which let’s you stream your music directly from your server.
What is my problem?
The point is that I want to install Ampache alongside Nextcloud. I installed Nextcloud in /var/www/html/ directory, I didn’t create the subdirectory /nextcloud in /var/www/. So, when I access my server through domain (it’s not my real domain, its only purpose is to show what I want to achieve): “cloud.mynextcloud.cloud”, it redirects me directly to Nextcloud. Ok, that’s fine, that is what I want, but I also want to install Ampache to work alongside Nextcloud. I want Ampache to access it through a subdirectory: “cloud.mynextcloud.cloud/ampache”.
Everything seems to be real easy to do, but it doesn’t work how I want to do so. When I created a directory /ampache in /var/www and when I uploaded a random HTML file (just to see if it’ll work) into this directory, I tried to test if it would open the random HTML file. It doesn’t seem to work, it always redirects me to Nextcloud.
What I ask you to help me with?
I would be extremely glad if you explained me what the cause of my problem is, and how to solve it.
I think that something is up with .htaccess file, but I am not sure. I also think that config.php might be helpful, but I know nothing. I do not want Nextcloud to work in a subdirectory, I redirected my subdomain on purspose, so that I can access Nextcloud without writing the directory after the domain.
I hope you understand what my problem is, and I will be grateful to any of you, who can help me.
Thank you, again!
