Nextcloud version: 12.0.5
Operating system and version : Debian 8.10
Apache or nginx version: nginx 1.12.2
PHP version : 7.1.13
Today I reinstalled my nextcloud and now it’s spawning an error that system enviorment variables cant be read. And that getenv (“PATH”) returns an empty anwser.
But that’s does not make much sense: When I run
sudo -u www-data printenv PATH
it returns
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Also in the poolconfig the following is set:
env[PATH] = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
That’s why I am pretty much surprised by this error… it just does not make any sense…
No error
'instanceid' => 'XXX',
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'XXX',
'datadirectory' => '/var/www/XXX',
'overwrite.cli.url' => 'XXX',
'version' => '12.0.5.3',
'dbname' => 'XXX',
'dbhost' => 'localhost',
'dbtableprefix' => 'XXX',
'dbuser' => 'XXX',
'dbpassword' => 'XXX',
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_domain' => 'XXX',
'mail_smtphost' => 'smtp.office365.com',
'mail_smtpport' => '587',
'mail_smtpname' => 'XXX',
'mail_smtppassword' => 'XXX',
nothing there
Would be glad if anybody knows what have broken it…
