Hey , I am trying to install nextcloud server with nginx .
I do not use proxy (nginx is communicating directly with nextcloud via container:9000 upstream)
I redirect all my communication to https. Including the nextcloud web URL.
And I am getting error curl 28 for timeout.
So I have decided to check nextcloud AIO to see if it will be supported there and I got an error that certificates are not found .
Which leads me to the question , does nextcloud supports certificates in other solutions except certbot or letβs encrypt ?
And if so , where do I need to put my certificates in order for nextcloud to reach the server and etc ?
