Nextcloud version: 29.0.5
Operating system and version : Ubuntu 20.04.6 LTS
Apache or nginx version: Apache/2.4.41
PHP version: 8.3
Is this the first time you’ve seen this error? Yes
- Install Collabora Online - Built-in CODE Server
- Install Nextcloud Office
- Configure (?) – This is what Nextcloud Office reports about the Built-in Server:
Collabora Online server is reachable.
Collabora Online Development Edition 24.04.5.2 ca2ed20
URL used by the browser: https://nextcloud.EXAMPLE.de
Nextcloud URL used by Collabora: https://nextcloud.EXAMPLE.de (Determined from the browser URL)
- I have no WOPI configured, because (sadly) I want it to be accessible for guests. (Which I hate myself, but it’s the requirement for this particular one…)
- When trying to access a file, I get a loading spinner that spins forever. The log shows a error message (see below).
Fetched remote endpoint from capabilities in 0.059 seconds
"Jul 26, 2024, 10:05:45 AM"
Error PHP
Trying to access array offset on null at /var/www/vhosts/EXAMPLE.de/nextcloud.EXAMPLE.de/apps/richdocuments/lib/Service/CachedRequestService.php#152
"Jul 26, 2024, 10:05:44 AM"
Error PHP
Trying to access array offset on null at /var/www/vhosts/EXAMPLE.de/nextcloud.EXAMPLE.de/apps/richdocuments/lib/Service/CachedRequestService.php#151
Error PHP
Trying to access array offset on null at /var/www/vhosts/EXAMPLE.de/nextcloud.EXAMPLE.de/apps/richdocuments/lib/Service/CachedRequestService.php#150
$CONFIG = array(
'instanceid' => 'EXAMPLEINSTANCEID',
'passwordsalt' => 'EXAMPLESALT',
'secret' => 'EXAMPLESECRET',
array(
0 => 'nextcloud.EXAMPLE.de',
'datadirectory' => realpath(__dir__ . '/../data'),
'overwrite.cli.url' => 'https://nextcloud.EXAMPLE.de',
'version' => '29.0.4.1',
'dbname' => 'nextcloud_db',
'dbhost' => '127.0.0.1',
'dbuser' => 'nextcloud_user',
'dbpassword' => 'EXAMPLEHASHEDPW',
'mail_from_address' => 'web',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'EXAMPLE.de',
'mail_smtphost' => 'smtp-mail.outlook.com',
'mail_smtpport' => '587',
'mail_smtpauth' => 1,
'mail_smtpname' => 'EXAMPLE@EXAMPLE.de',
'mail_smtppassword' => 'SUPEREXAMPLEPW',
'redis' =>
array(
'host' => '127.0.0.1',
'port' => 6379,
'loglevel' => 0,
'default_language' => 'en',
'force_language' => 'en',
[Fri Jul 26 10:31:56.000378 2024] [fcgid:warn] [pid 2773984] [client 95.130.163.96:0] mod_fcgid: stderr: PHP Warning: http_response_code(): Cannot set response code - headers already sent (output started at /var/www/vhosts/EXAMPLE.de/nextcloud.EXAMPLE.de/apps/richdocumentscode/proxy.php on line 292
Not quite sure where to find this to be honest. Don’t have those logs on my server, so maybe they’re someplace else – and I don’t know what topright menu this is referring to, I’m not saying anything quite like a log there.
