Steps to reproduce
upgrade from 28.0.12 --29.0.9 —30.0.2
open a word file.
An issue happens, when you open a word document, you cannot view it online, instead, it’s downloaded automatically.
Expected behavior
Could use Collabora online.
Nextcloud Server version
30
Operating system
Debian/Ubuntu
PHP engine version
PHP 8.3
Web server
Nginx
Database engine version
MariaDB
Is this bug present after an update or on a fresh install?
Upgraded to a MAJOR version (ex. 28 to 29)
Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
What user-backends are you using?
Default user-backend (database)
LDAP/ Active Directory
SSO - SAML
Other
Configuration report
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"proxy": "172.16.232.21:8088",
"nextcloud-uat.pacific-textiles.com",
"172.16.205.55",
"https:\/\/nextcloud-uat.pacific-textiles.com",
"https:\/\/nextcloud-uat.pacific-textiles.com:8443",
"next.pacific-textiles.com"
"forwarded_for_headers": [
"HTTP_X_FORWARDED_FOR",
"X-Forwarded-For"
"dbtype": "mysql",
"version": "30.0.2.2",
"overwrite.cli.url": "https:\/\/nextcloud-uat.pacific-textiles.com",
"overwriteprotocol": "https",
"dbport": "",
"mysql.utf8mb4": true,
"allow_local_remote_servers": "true",
"ldapIgnoreNamingRules": false,
"sharing.enable_share_accept": true,
"sharing.force_share_accept": true,
"twofactor_enforced": "true",
"twofactor_enforced_groups": [],
"twofactor_enforced_excluded_groups": [
"warehouse",
"SAP-CONSULTANT",
"monitor",
"SAP-KU",
"customs-i&e",
"accounts-macao",
"raw_material",
"Nextcloud-No-Otp"
"onlyoffice": {
"verify_peer_off": true
"loglevel": "2",
"theme": "example",
"redis": {
"port": 6379
"app_install_overwrite": [
"accessibility",
"fulltextsearch_elasticsearch"
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"mail_smtpport": "25",
"mail_smtppassword": "***REMOVED SENSITIVE VALUE***"
{"reqId":"8ZXZtaV4xfiZS9Ydi6qM","level":3,"time":"2024-11-26T06:02:50+00:00","remoteAddr":"172.30.20.234","user":"root","app":"richdocuments","method":"GET","url":"/core/preview?fileId=408871&x=250&y=250","message":"Failed to convert preview: cURL error 28: Operation timed out after 5001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://collabora-uat.pacific-textiles.com/cool/convert-to/png","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36","version":"30.0.2.2","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Operation timed out after 5001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://collabora-uat.pacific-textiles.com/cool/convert-to/png","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[{"__class__":"GuzzleHttp\\Handler\\CurlHandler"},"*** sensitive parameters replaced ***",{"__class__":"GuzzleHttp\\Handler\\CurlFactory"}]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[{"__class__":"GuzzleHttp\\Handler\\CurlHandler"},"*** sensitive parameters replaced ***",{"__class__":"GuzzleHttp\\Handler\\CurlFactory"}]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":142,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/DnsPinMiddleware.php","line":106,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":64,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":66,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":333,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":169,"function":"transfer","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/Client.php","line":276,"function":"request","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",{"verify":"/var/www/html/resources/config/ca-bundle.crt","timeout":5,"proxy":{"http":"172.16.232.21:8088","https":"172.16.232.21:8088"},"nextcloud":{"allow_local_address":true},"expect":false,"0":"And 3 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/RemoteService.php","line":92,"function":"post","class":"OC\\Http\\Client\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/RemoteService.php","line":72,"function":"convertTo","class":"OCA\\Richdocuments\\Service\\RemoteService","type":"->","args":["GZ-GEN-3-012-20241121-001 IT\u670d\u52a1\u8fd0\u7ef4\u62a5\u544a\u30101\u6708-10\u6708\u3011V2.0.pptx",null,"png"]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Preview/Office.php","line":41,"function":"convertFileTo","class":"OCA\\Richdocuments\\Service\\RemoteService","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},"png"]},{"file":"/var/www/html/lib/private/Preview/GeneratorHelper.php","line":44,"function":"getThumbnail","class":"OCA\\Richdocuments\\Preview\\Office","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},4096,4096]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":337,"function":"getThumbnail","class":"OC\\Preview\\GeneratorHelper","type":"->","args":[{"__class__":"OCA\\Richdocuments\\Preview\\OOXML"},{"__class__":"OC\\Files\\Node\\File"},4096,4096]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":313,"function":"generateProviderPreview","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\SimpleFS\\SimpleFolder"},{"__class__":"OC\\Files\\Node\\File"},4096,4096,false,true,"application/vnd.openxmlformats-officedocument.presentationml.presentation",""]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":119,"function":"getMaxPreview","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\SimpleFS\\SimpleFolder"},[],{"__class__":"OC\\Files\\Node\\File"},"application/vnd.openxmlformats-officedocument.presentationml.presentation",""]},{"file":"/var/www/html/lib/private/Preview/Generator.php","line":86,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},[{"width":250,"height":250,"crop":true,"mode":"fill"}],"application/vnd.openxmlformats-officedocument.presentationml.presentation"]},{"file":"/var/www/html/lib/private/PreviewManager.php","line":167,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},250,250,true,"fill",null]},{"file":"/var/www/html/core/Controller/PreviewController.php","line":159,"function":"getPreview","class":"OC\\PreviewManager","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},250,250,true,"fill"]},{"file":"/var/www/html/core/Controller/PreviewController.php","line":123,"function":"fetchPreview","class":"OC\\Core\\Controller\\PreviewController","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"},250,250,false,true,"fill",false]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":208,"function":"getPreviewByFileId","class":"OC\\Core\\Controller\\PreviewController","type":"->","args":[408871,250,250,false,true,"fill",false]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":114,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\PreviewController"},"getPreviewByFileId"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":161,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\PreviewController"},"getPreviewByFileId"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OC\\Core\\Controller\\PreviewController","getPreviewByFileId",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"core.preview.getpreviewbyfileid"}]},{"file":"/var/www/html/lib/base.php","line":1001,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/core/preview"]},{"file":"/var/www/html/index.php","line":24,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":210,"message":"Failed to convert preview: cURL error 28: Operation timed out after 5001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://collabora-uat.pacific-textiles.com/cool/convert-to/png","exception":{},"CustomMessage":"Failed to convert preview: cURL error 28: Operation timed out after 5001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://collabora-uat.pacific-textiles.com/cool/convert-to/png"}}
