Hi there,
Last week my ISP had a major outage and when my internet came back up I was assigned a new IP address. I switched the few apps I have to the new IP but have found that some of them fail. Despite having the correct ports forwarded and dialing the new IP address, nextcloud won’t sync to my server. Other apps fail while some still work. Ive tried updating the apps with no success, but I’m at a loss at this point. Here is the errror log I’ve been getting:
Exception: {"Message":"HTTP\/1.1 415 Unsupported Media Type","Exception":"Sabre\\DAV\\Exception\\ReportNotSupported","Code":0,"Trace":"#0 [internal function]: Sabre\\DAV\\CorePlugin->httpReport(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/usr\/pbi\/nextcloud-amd64\/www\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 \/usr\/pbi\/nextcloud-amd64\/www\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(459): Sabre\\Event\\EventEmitter->emit('method:REPORT', Array)\n#3 \/usr\/pbi\/nextcloud-amd64\/www\/nextcloud\/3rdparty\/sabr
Thanks for the help
