Nextcloud version 13.0.6)
Operating system Ubuntu server 18.04
Apache or nginx version apache2
PHP version 7.2
The issue you are facing: Nothing is working on chrome (only on IE)
Is this the first time you’ve seen this error? Y
- Install nextcloud
Litterly nothing
'instanceid' => '<iid>',
'passwordsalt' => '<pass>',
'secret' => '<secret>',
0 => '<mydomain>',
1 => '<myip>',
'overwrite.cli.url' => '<mysite>',
'version' => '13.0.6.1',
'dbname' => 'nextcloud',
'dbhost' => '<db_host>',
'dbuser' => 'oc_roy1',
'dbpassword' => '<dbpass>',
'updater.secret' => '<sec>',
'theme' => '',
'loglevel' => 2,
: (wasnt able to access this so I posted my chrome console errors)
Refused to load the script 'https://amp.cloudflare.com/viewer/rtv/011-4-71/amp-viewer.js' because it violates the following Content Security Policy directive: "script-src 'self' 'unsafe-eval'".
login:1 Refused to load the script 'https://ajax.cloudflare.com/cdn-cgi/scripts/2448a7bd/cloudflare-static/rocket-loader.min.js' because it violates the following Content Security Policy directive: "script-src 'self' 'unsafe-eval'".
22Refused to load the font '<URL>' because it violates the following Content Security Policy directive: "font-src 'self'".
[Intervention] Slow network is detected. See https://www.chromestatus.com/feature/5636954674692096 for more details. Fallback font will be used while loading: https://cloud.royzonneveld.nl/core/fonts/OpenSans-Light.woff
[Intervention] Slow network is detected. See https://www.chromestatus.com/feature/5636954674692096 for more details. Fallback font will be used while loading: https://cloud.royzonneveld.nl/core/fonts/OpenSans-Semibold.woff
