NextCloud Not Syncing on One System
    • 31.0.9
    • Operating System: Manjaro Linux
      KDE Plasma Version: 6.3.6
      KDE Frameworks Version: 6.18.0
      Qt Version: 6.9.2
      Kernel Version: 6.16.8-1-MANJARO (64-bit)
    • Running httpd -v and apachectl -v both give me command not found.
    • None
    • Running php --version gives me command not found.
    • Within the last month.
    • Not sure (been a long time, probably just directly from repos)
I have multiple systems that sync to my server. Everything is running fully updated Manjaro OS. My wife was going to start sorting photos on her laptop and we realized that her system isn’t synced. I checked mine and it’s synced fine.
Things I’ve tried:
(1) Rebooting
(2) Logging out of NextCloud
(3) Stopping sync and restarting it
In NextCloud settings on the client it just perpetually shows “Synchronizing files in local folder”. Sometimes (appears like right when I start NextCloud or pause and then start sync) I’ll see something like 0 of
  1. Synchronizing fails every time I run NextCloud desktop client on this system. Not sure what triggered it to start.
Looks like it’s claiming the sync is successful (it definitely isn’t). These are from the last lines on my sync log from client (Pictures_Sync.log located in ~./local/share/NextCloud
#=#=#=# Syncrun finished 2025-09-10T00:25:35Z (last step: 11702 msec, total: 12161 msec)
#=#=#=# Syncrun started 2025-09-10T00:26:05Z
#=#=#=#=# Propagation starts 2025-09-10T00:26:06Z (last step: 633 msec, total: 633 msec)
#=#=#=# Syncrun finished 2025-09-10T00:26:06Z (last step: 7 msec, total: 640 msec)
#=#=#=# Syncrun started 2025-09-10T00:30:06Z
#=#=#=# Syncrun finished 2025-09-10T00:33:52Z (last step: 225982 msec, total: 225982 msec)
#=#=#=# Syncrun started 2025-09-10T00:35:01Z
#=#=#=# Syncrun started 2025-09-19T16:37:59Z
#=#=#=# Syncrun started 2025-09-25T20:02:42Z
#=#=#=# Syncrun started 2025-09-30T23:41:07Z
#=#=#=# Syncrun started 2025-10-10T16:09:02Z
#=#=#=# Syncrun started 2025-10-17T00:54:25Z
#=#=#=# Syncrun started 2025-10-21T03:30:53Z
#=#=#=# Syncrun started 2025-10-21T13:24:38Z
#=#=#=# Syncrun started 2025-10-21T13:32:07Z
#=#=#=# Syncrun finished 2025-10-21T13:34:46Z (last step: 158863 msec, total: 158863 msec)
#=#=#=# Syncrun started 2025-10-21T13:36:33Z
#=#=#=# Syncrun finished 2025-10-21T13:43:16Z (last step: 403419 msec, total: 403419 msec)
#=#=#=# Syncrun started 2025-10-21T13:43:48Z
#=#=#=# Syncrun finished 2025-10-21T13:45:16Z (last step: 88552 msec, total: 88552 msec)
#=#=#=# Syncrun started 2025-10-21T13:45:31Z
#=#=#=# Syncrun finished 2025-10-21T13:57:23Z (last step: 711963 msec, total: 711963 msec)
#=#=#=# Syncrun started 2025-10-21T13:58:20Z
#=#=#=# Syncrun finished 2025-10-21T14:11:10Z (last step: 770269 msec, total: 770269 msec)
#=#=#=# Syncrun started 2025-10-21T14:11:55Z
#=#=#=# Syncrun finished 2025-10-21T19:31:03Z (last step: 19148137 msec, total: 19148137 msec)
#=#=#=# Syncrun started 2025-10-21T19:32:03Z
From what I can see, there are no logs (see screenshot below) from the relevant period of time. I had a couple of missed logins but nothing about syncing. It's currently 4:26pm, I just did an attempt to force sync, and last log is from bad login attempt hours ago.
I tried locating nextcloud.log but couldn’t find the right one.
Maybe this is the log that’s needed: JustPaste.it - Share Text & Images the Easy Way
All -
I had “fixed” this by removing the sync and setting it up again. Now I’m back as the system again has hit the same problem. I see this from the client:
The “checking folder changes” never changes and no sync happens. I just noticed that the client is seeing that I have new items uploaded to server side (from my phone, auto uploading photos) - noted by the list showing uploads 1m before, but these are never pulled/synced to the client. My other client works fine. My wife is about to force me off of NextCloud because it’s her computer that is the issue and she’s sick of the issue appearing.
Here is a link to the entirety of my logs: Google Drive Logs
You said your other client is working fine?
How did you install the clients? And what version? (Saying latest isn’t helpful since there’s a huge difference between distro ones versus other sources).
Can you also share more about how each client is configured, what the underlying folder(s) are you’re sharing, etc.
P.S. The reason a lot of the commands gave no output or didn’t work is because they’re commands for the Nextcloud Server not your client devices.
Correct
Both are identical Manjaro systems (even both are Dell XPS systems, mine is just beefier). Both installed Next Cloud client via repo
That makes sense. I don’t think server is the issue, something about the client.
Just my photo/videos directory that I use to sync between various phones (auto uploading) and then to server to two Manjaro XPS laptops. Nothing too fancy. Both use the same Next Cloud profile (“Public”) as it’s shared items between my wife and myself.
If so, you may try to mount the NC-Servers Folder via WebDAV and simply try rsync -uva to sync the Files and subfolders. If it is the client and nothing else it shall work then.
