Nextcloud version : 27.0.1
Operating system and version : DEBIAN 11
Machine : VPS
Nginx version : replace me
PHP version : replace me
Nextcloud cannot be reached, I get a 504 Gateway Time Out issue.
I think (not 100% sure) that the issue happened while some files were being uploaded from a phone using the Nextcloud app. This kind of uploading is done regularly and I’ve never had a problem.
Nextcloud has been upgraded from 26.0.3 a few days before without any issue.
Is this the first time you’ve seen this error? (Y/N): Yes
Below you will find an abstract from /nextcloud/data/nextcloud.log
{"reqId":"8r9Gqkb4EIetvkGW6wXv","level":3,"time":"2023-07-26T10:40:04+00:00","remoteAddr":"82.64.173.18","user":"gaelle","app":"PHP","method":"POST","url":"/nextcloud/remote.php/dav/bulk","message":"Undefined array key 1 at /var/www/nextcloud/apps/dav/lib/BulkUpload/MultipartRequestParser.php#183","userAgent":"Mozilla/5.0 (Linux) mirall/3.8.2 (build 15392) (Nextcloud, debian-4.19.0-24-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"27.0.1.2","data":{"app":"PHP"}}
{"reqId":"8r9Gqkb4EIetvkGW6wXv","level":3,"time":"2023-07-26T10:40:04+00:00","remoteAddr":"82.64.173.18","user":"gaelle","app":"no app in context","method":"POST","url":"/nextcloud/remote.php/dav/bulk","message":"An exception occurred while executing a query: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '45149-1690368004' for key 'files_versions_uniq_index'","userAgent":"Mozilla/5.0 (Linux) mirall/3.8.2 (build 15392) (Nextcloud, debian-4.19.0-24-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"27.0.1.2","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '45149-1690368004' for key 'files_versions_uniq_index'","Code":1062,"Trace":[{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":328,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::"},{"file":"/var/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php","line":137,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":192,"function":"insert","class":"OCP\\AppFramework\\Db\\QBMapper","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":240,"function":"created","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":111,"function":"post_write_hook","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":86,"function":"handle","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":94,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":106,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/HookConnector.php","line":121,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Hook.php","line":105,"function":"postWrite","class":"OC\\Files\\Node\\HookConnector","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1257,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1184,"function":"runHooks","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":670,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","line":188,"function":"file_put_contents","class":"OC\\Files\\View","type":"->"},{"function":"newFile","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":74,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":428,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BulkUpload/BulkUploadPlugin.php","line":92,"function":"newFile","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPost","class":"OCA\\DAV\\BulkUpload\\BulkUploadPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":364,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/Exceptions/DbalException.php","Line":71,"Previous":{"Exception":"Doctrine\\DBAL\\Exception\\UniqueConstraintViolationException","Message":"An exception occurred while executing a query: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '45149-1690368004' for key 'files_versions_uniq_index'","Code":1062,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1814,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1749,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":295,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":326,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php","line":137,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":192,"function":"insert","class":"OCP\\AppFramework\\Db\\QBMapper","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":240,"function":"created","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":111,"function":"post_write_hook","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":86,"function":"handle","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":94,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":106,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/HookConnector.php","line":121,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Hook.php","line":105,"function":"postWrite","class":"OC\\Files\\Node\\HookConnector","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1257,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1184,"function":"runHooks","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":670,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","line":188,"function":"file_put_contents","class":"OC\\Files\\View","type":"->"},{"function":"newFile","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":74,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":428,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BulkUpload/BulkUploadPlugin.php","line":92,"function":"newFile","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPost","class":"OCA\\DAV\\BulkUpload\\BulkUploadPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":364,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":64,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '45149-1690368004' for key 'files_versions_uniq_index'","Code":1062,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":103,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1153,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":295,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":326,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php","line":137,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":192,"function":"insert","class":"OCP\\AppFramework\\Db\\QBMapper","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":240,"function":"created","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":111,"function":"post_write_hook","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":86,"function":"handle","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":94,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":106,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/HookConnector.php","line":121,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Hook.php","line":105,"function":"postWrite","class":"OC\\Files\\Node\\HookConnector","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1257,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1184,"function":"runHooks","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":670,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","line":188,"function":"file_put_contents","class":"OC\\Files\\View","type":"->"},{"function":"newFile","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":74,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":428,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BulkUpload/BulkUploadPlugin.php","line":92,"function":"newFile","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPost","class":"OCA\\DAV\\BulkUpload\\BulkUploadPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":364,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":30,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '45149-1690368004' for key 'files_versions_uniq_index'","Code":"23000","Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":101,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1153,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":295,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":326,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/public/AppFramework/Db/QBMapper.php","line":137,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":192,"function":"insert","class":"OCP\\AppFramework\\Db\\QBMapper","type":"->"},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":240,"function":"created","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/files_versions/lib/Listener/FileEventsListener.php","line":111,"function":"post_write_hook","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":86,"function":"handle","class":"OCA\\Files_Versions\\Listener\\FileEventsListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":94,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":106,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/HookConnector.php","line":121,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Hook.php","line":105,"function":"postWrite","class":"OC\\Files\\Node\\HookConnector","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1257,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1184,"function":"runHooks","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":670,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","line":188,"function":"file_put_contents","class":"OC\\Files\\View","type":"->"},{"function":"newFile","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":74,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":428,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/BulkUpload/BulkUploadPlugin.php","line":92,"function":"newFile","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPost","class":"OCA\\DAV\\BulkUpload\\BulkUploadPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":364,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":172,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":101}}},"CustomMessage":"--"}}
{"reqId":"o9nRM0p3bdl9HMNaA1tt","level":3,"time":"2023-07-26T11:20:02+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job (class: OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions, arguments: )","userAgent":"--","version":"27.0.1.2","exception":{"Exception":"TypeError","Message":"OCA\\GroupFolders\\ACL\\ACLManagerFactory::getACLManager(): Argument #1 ($user) must be of type OCP\\IUser, null given, called in /var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php on line 206","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":206,"function":"getACLManager","class":"OCA\\GroupFolders\\ACL\\ACLManagerFactory","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php","line":172,"function":"getMount","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Versions/GroupVersionsExpireManager.php","line":68,"function":"getAllVersionedFiles","class":"OCA\\GroupFolders\\Versions\\VersionsBackend","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Versions/GroupVersionsExpireManager.php","line":59,"function":"expireFolder","class":"OCA\\GroupFolders\\Versions\\GroupVersionsExpireManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/BackgroundJob/ExpireGroupVersions.php","line":43,"function":"expireAll","class":"OCA\\GroupFolders\\Versions\\GroupVersionsExpireManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":86,"function":"run","class":"OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":103,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":93,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/nextcloud/apps/groupfolders/lib/ACL/ACLManagerFactory.php","Line":37,"message":"Error while running background job (class: OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions, arguments: )","exception":{},"CustomMessage":"Error while running background job (class: OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions, arguments: )"}}
{"reqId":"zDFsISNqwKdbT1hu5RnU","level":3,"time":"2023-07-26T12:25:02+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job (class: OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions, arguments: )","userAgent":"--","version":"27.0.1.2","exception":{"Exception":"TypeError","Message":"OCA\\GroupFolders\\ACL\\ACLManagerFactory::getACLManager(): Argument #1 ($user) must be of type OCP\\IUser, null given, called in /var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php on line 206","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":206,"function":"getACLManager","class":"OCA\\GroupFolders\\ACL\\ACLManagerFactory","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php","line":172,"function":"getMount","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Versions/GroupVersionsExpireManager.php","line":68,"function":"getAllVersionedFiles","class":"OCA\\GroupFolders\\Versions\\VersionsBackend","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Versions/GroupVersionsExpireManager.php","line":59,"function":"expireFolder","class":"OCA\\GroupFolders\\Versions\\GroupVersionsExpireManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/BackgroundJob/ExpireGroupVersions.php","line":43,"function":"expireAll","class":"OCA\\GroupFolders\\Versions\\GroupVersionsExpireManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":86,"function":"run","class":"OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":103,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":93,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/nextcloud/apps/groupfolders/lib/ACL/ACLManagerFactory.php","Line":37,"message":"Error while running background job (class: OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions, arguments: )","exception":{},"CustomMessage":"Error while running background job (class: OCA\\GroupFolders\\BackgroundJob\\ExpireGroupVersions, arguments: )"}}
Where could I look in order to solve this issue ?
Thank you for your help
