Since a few weeks I cannot reach my Nextcloud instance
I tried to reinstall (snap)
and set back a backup of installation and files
However it does not work
I got multiple errors but none of them seemed to get to sollution
Now I wonder if there is a simple reason such as unsufficient space
My specifications from the server:
Ubuntu 20.04.1 LTS (GNU/Linux 5.4.0-56-generic x86_64)
System information as of di 1 dec 2020 16:59:40 CET
System load: 0.09
Usage of /: 5.8% of 3.58TB
Memory usage: 6%
Swap usage: 0%
Temperature: 37.0 C
Processes: 212
Users logged in: 0
IPv4 address for docker0:
IPv4 address for eno1:
IPv6 address for eno1:
0 updates can be installed immediately.
0 of these updates are security updates.
root@server1:/# root@server1:/# df -h
bash: root@server1:/#: No such file or directory
root@server1:/# Filesystem Size Used Avail Use% Mounted on
tmpfs 7,8G 0 7,8G 0% /dev/shm
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 7,8G 0 7,8G 0% /sys/fs/cgroup
/dev/sdb1 511M 7,8M 504M 2% /boot/efi
/dev/loop2 56M 56M 0 100% /snap/core18/1885
/dev/loop1 98M 98M 0 100% /snap/core/10126
/dev/loop3 126M 126M 0 100% /snap/docker/471
/dev/loop4 56M 56M 0 100% /snap/core18/1932
/dev/loop0 98M 98M 0 100% /snap/core/10185
/dev/loop5 68M 68M 0 100% /snap/lxd/18150
/dev/loop6 9,2M 9,2M 0 100% /snap/canonical-livepatch/94
/dev/loop7 9,2M 9,2M 0 100% /snap/canonical-livepatch/95
/dev/loop8 4,3M 4,3M 0 100% /snap/tree/18
/dev/loop11 126M 126M 0 100% /snap/docker/461
/dev/loop10 71M 71M 0 100% /snap/lxd/16922
/dev/loop9 253M 253M 0 100% /snap/nextcloud/23743
tmpfs 1,6G 0 1,6G 0% /run/user/1000
Is there any sollution in this problem?
