Nextcloud version : 20.0.1 (Docker)
Operating system and version: Ubuntu 20.04
Apache or nginx version: n/a
PHP version: whatever is included in the nextcloud image
I’m trying to move my Nextcloud 20.0.1 instance to use an NFS mount instead of a filesystem mount. (Note: I’m running this on Kubernetes using the nextcloud Docker image).
When I change the /var/www/html
mount to point to the NFS share (I’ve already rsync
ed the data from one to the other) and update the deployment, I can see it mounts the NFS volume correctly, and I can cat
the files in there so I know the filesystem has mounted and is readable. Permissions are correct also.
However, whenever I try to access the server through my web browser, it hangs, and eventually times out. Also, if I try to execute e.g., ./occ status
it also hangs. I’m assuming from this that there’s something different in the NFS semantics, possibly having to do with how PHP locks files?
The mount itself looks like this:
10.1.2.3:/export/[redacted] on /var/www/html type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.1.2.3,mountvers=3,mountport=20048,mountproto=udp,local_lock=none,addr=10.1.2.3)
I’ve tried moving nextcloud.log
to /tmp
to see if that would fix it; no joy.
I should mention that I have other Apache/PHP applications (Rainloop) that I have successfully migrated to NFS without issue.
Is there anything wrong with that mount that would cause these symptoms? I can’t seem to find an answer.
Is this the first time you’ve seen this error? Y
- Mount
/var/www/html
from an NFS volume - Do anything involving PHP (serve a web page, run
occ
) - Watch it hang.
None
'instanceid' => 'nope',
'passwordsalt' => 'nope',
0 => 'nope',
1 => 'nope',
'objectstore' =>
'class' => 'OC\\Files\\ObjectStore\\S3',
'arguments' =>
'bucket' => 'nope',
'autocreate' => true,
'key' => 'nope',
'secret' => 'nope',
'region' => 'nope',
'hostname' => 'nope',
'port' => 9000,
'use_ssl' => false,
'use_path_style' => true,
'version' => '20.0.1.1',
'dbtype' => 'pgsql',
'dbhost' => 'nope',
'dbname' => 'nope',
'dbuser' => 'nope',
'dbpassword' => 'nope',
'default_language' => 'en',
'defaultapp' => 'files',
'knowledgebaseenabled' => true,
'enable_avatars' => true,
'allow_user_to_change_display_name' => true,
'remember_login_cookie_lifetime' => 1296000,
'session_lifetime' => 86400,
'session_keepalive' => true,
'skeletondirectory' => '',
'lost_password_link' => '',
'mail_domain' => 'nope',
'mail_from_address' => 'nope',
'mail_smtpdebug' => false,
'mail_smtpmode' => 'smtp',
'mail_smtphost' => 'nope',
'mail_smtpport' => '587',
'mail_smtptimeout' => 10,
'mail_smtpauth' => 1,
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpname' => 'nope',
'mail_smtppassword' => 'nope',
'overwritehost' => 'cloud.koehn.com',
'overwritewebroot' => '/',
'overwritecondaddr' => '',
'overwrite.cli.url' => 'https://cloud.koehn.com',
'trashbin_retention_obligation' => 'auto',
'versions_retention_obligation' => 'auto',
'appcodechecker' => false,
'updatechecker' => true,
'updater.server.url' => 'https://updates.nextcloud.com/updater_server/',
'has_internet_connection' => true,
'check_for_working_webdav' => true,
'check_for_working_wellknown_setup' => true,
'check_for_working_htaccess' => true,
'config_is_read_only' => false,
'log_type' => 'owncloud',
'logfile' => '/var/www/html/data/nextcloud.log',
'loglevel' => 2,
'syslog_tag' => 'Nextcloud',
'log.condition' =>
'shared_secret' => 'nope',
'users' =>
0 => 'sample-user',
'apps' =>
0 => 'files',
'logdateformat' => 'F d, Y H:i:s',
'log_query' => false,
'cron_log' => true,
'log_rotate_size' => 10485760,
'customclient_desktop' => 'https://nextcloud.com/install/',
'customclient_android' => 'https://play.google.com/store/apps/details?id=com.nextcloud.client',
'customclient_ios' => 'https://itunes.apple.com/us/app/nextcloud/id1125420102?mt=8',
'appstoreenabled' => true,
'appstore.experimental.enabled' => true,
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'enable_previews' => true,
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'preview_max_scale_factor' => 10,
'preview_max_filesize_image' => 50,
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'preview_office_cl_parameters' => ' --headless --nologo --nofirststartwizard --invisible --norestore --convert-to pdf --outdir ',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\MP3',
6 => 'OC\\Preview\\TXT',
7 => 'OC\\Preview\\MarkDown',
8 => 'OC\\Preview\\PDF',
'ldapUserCleanupInterval' => 51,
'comments.managerFactory' => '\\OC\\Comments\\ManagerFactory',
'systemtags.managerFactory' => '\\OC\\SystemTag\\ManagerFactory',
'singleuser' => false,
'enable_certificate_management' => false,
'redis' =>
'host' => 'redis',
'port' => 6379,
'timeout' => 0.0,
'memcached_servers' =>
0 =>
0 => 'memcached',
1 => 11211,
'memcached_options' =>
14 => 50,
15 => 50,
19 => 50,
20 => 50,
8 => 50,
-1001 => true,
16 => true,
18 => true,
'cache_path' => '',
'cache_chunk_gc_ttl' => 86400,
'sharing.managerFactory' => '\\OC\\Share20\\ProviderFactory',
'sqlite.journal_mode' => 'DELETE',
'supportedDatabases' =>
0 => 'sqlite',
1 => 'mysql',
2 => 'pgsql',
3 => 'oci',
'tempdirectory' => '/tmp',
'hashingCost' => 10,
'blacklisted_files' =>
0 => '.htaccess',
'share_folder' => '/',
'theme' => '',
'cipher' => 'AES-256-CFB',
'minimum.supported.desktop.version' => '1.7.0',
'quota_include_external_storage' => false,
'filesystem_check_changes' => 0,
'part_file_in_storage' => true,
'mount_file' => '/var/www/nextcloud/data/mount.json',
'filesystem_cache_readonly' => false,
'secret' => '',
'trusted_proxies' =>
0 => 'nope',
1 => 'nope',
'forwarded_for_headers' =>
0 => 'HTTP_X_FORWARDED',
1 => 'HTTP_FORWARDED_FOR',
'max_filesize_animated_gifs_public_sharing' => 10,
'filelocking.ttl' => 3600,
'upgrade.disable-web' => false,
'debug' => false,
'data-fingerprint' => 'nope',
'mail_smtpsecure' => 'tls',
'app_install_overwrite' =>
0 => 'apporder',
1 => 'calendar',
2 => 'drawio',
[Fri Oct 30 15:13:19.157849 2020] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.38 (Debian) PHP/7.4.11 configured -- resuming normal operations
[Fri Oct 30 15:13:19.157894 2020] [core:notice] [pid 1] AH00094: Command line: 'apache2 -D FOREGROUND'
10.244.4.182 - - [30/Oct/2020:15:13:19 +0000] "GET / HTTP/1.1" 200 622 "-" "curl/7.64.1"
10.244.4.182 - x [30/Oct/2020:15:13:19 +0000] "PROPFIND /remote.php/dav/files/bkoehn/ HTTP/1.1" 200 646 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.1git (build 3355) (Nextcloud)"
10.244.4.182 - y [30/Oct/2020:15:13:19 +0000] "GET /status.php HTTP/1.1" 500 639 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
10.244.4.182 - - [30/Oct/2020:15:13:19 +0000] "GET / HTTP/1.1" 200 608 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.16; rv:82.0) Gecko/20100101 Firefox/82.0"
10.244.4.182 - y [30/Oct/2020:15:13:38 +0000] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 200 763 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
10.244.4.182 - y [30/Oct/2020:15:13:41 +0000] "GET /status.php HTTP/1.1" 500 639 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
127.0.0.1 - - [30/Oct/2020:15:14:42 +0000] "OPTIONS * HTTP/1.0" 200 126 "-" "Apache/2.4.38 (Debian) PHP/7.4.11 (internal dummy connection)"
10.244.4.182 - - [30/Oct/2020:15:13:46 +0000] "GET / HTTP/1.1" 200 608 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.16; rv:82.0) Gecko/20100101 Firefox/82.0"
10.244.4.182 - x [30/Oct/2020:15:13:51 +0000] "PROPFIND /remote.php/dav/files/bkoehn/ HTTP/1.1" 200 646 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.1git (build 3355) (Nextcloud)"
10.244.4.182 - - [30/Oct/2020:15:13:51 +0000] "GET / HTTP/1.1" 200 608 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.16; rv:82.0) Gecko/20100101 Firefox/82.0"
10.244.4.182 - y [30/Oct/2020:15:14:10 +0000] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 200 763 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
10.244.4.182 - y [30/Oct/2020:15:14:13 +0000] "GET /status.php HTTP/1.1" 500 639 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
10.244.4.182 - y [30/Oct/2020:15:14:42 +0000] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 200 763 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
10.244.4.182 - y [30/Oct/2020:15:14:45 +0000] "GET /status.php HTTP/1.1" 500 639 "-" "Mozilla/5.0 (Macintosh) mirall/2.6.5stable (build 20200710) (Nextcloud)"
10.244.4.182 - - [30/Oct/2020:15:14:51 +0000] "GET / HTTP/1.1" 200 608 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.16; rv:82.0) Gecko/20100101 Firefox/82.0"
10.244.4.182 - x [30/Oct/2020:15:14:53 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json HTTP/1.1" 200 763 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.1git (build 3355) (Nextcloud)"
