Nextcloud version : 20.0.1
Operating system and version : Ubuntu 20.04
Apache or nginx version : Nginx 1.18.0
PHP version : 7.4.3
We want to use NextCloud for different companies (multi-tenant). Will it be correct to install multiple NextCloud execs (/var/www/nextcloud/company1 and /var/www/nextcloud/company2) with different nginx config files, different databases and different file storage folders. Are there risks of data leakage from their company1 to company2, will the load on the server greatly increase?
nginx conf company1
upstream php-handler {
server unix:/var/run/php/php7.4-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name company1.nextcloud.kz;
return 301 https://$server_name:443$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/ssl/certs/company1.nextcloud.kz.crt;
ssl_certificate_key /etc/ssl/private/company1.nextcloud.kz.rsa;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
root /var/www/nextcloud/company1;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
return 301 $scheme://$host:$server_port/remote.php/dav;
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
location / {
rewrite ^ /index.php;
location /netdata {
return 301 /netdata/;
location ~ /netdata/(?<ndpath>.*) {
auth_basic "Shelya Parolen Vpisaten";
auth_basic_user_file /etc/nginx/netdata-access;
proxy_http_version 1.1;
proxy_pass_request_headers on;
proxy_set_header Connection "keep-alive";
proxy_store off;
proxy_pass http://netdata/$ndpath$is_args$args;
gzip on;
gzip_proxied any;
gzip_types *;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)$ {
access_log off;
nginx conf company2
server {
listen 80;
listen [::]:80;
server_name company2.nextcloud.kz;
server {
ssl_certificate /etc/ssl/certs/company2.nextcloud.kz.crt;
ssl_certificate_key /etc/ssl/private/company2.nextcloud.kz.rsa;
root /var/www/nextcloud/company2;
allow all;
log_not_found off;
access_log off;
gzip on;
gzip_vary on;
gzip_comp_level 4;
location / {
location /netdata {
proxy_store off;
gzip on;
gzip_proxied any;
gzip_types *;
deny all;
deny all;
index index.php;
access_log off;
access_log off;
nexcloud conf company1
'instanceid' => '###',
'passwordsalt' => '###',
'secret' => '###',
0 => 'company1.nextcloud.kz',
1 => '###',
'trusted_proxies' =>
0 => '###',
1 => '###',
'datadirectory' => '/mnt/ncdata/company1',
'version' => '20.0.1.1',
'overwrite.cli.url' => 'https://company1.nextcloud.kz',
'overwritehost' => 'company1.nextcloud.kz',
'dbname' => '###',
'dbhost' => '###',
'dbuser' => '###',
'dbpassword' => '###',
'versions_retention_obligation' => 'auto, 365',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => '###',
'mail_smtpport' => '25',
'mail_from_address' => '###',
'mail_domain' => '###',
'redis' =>
'host' => '###',
'port' => 6379,
'log_type' => 'file',
'logfile' => '/var/log/nextcloud/company1-nextcloud.log',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'remember_login_cookie_lifetime' => '1800',
'log_rotate_size' => '10485760',
'trashbin_retention_obligation' => 'auto, 180',
'default_language' => 'ru',
'defaultapp' => 'files',
'auth.bruteforce.protection.enabled' => true,
'encryption.legacy_format_support' => false,
'encryption.key_storage_migrated' => false,
'skeletondirectory' => '',
nextcloud conf company2
'secret' => '###',
0 => 'company2.nextcloud.kz',
1 => '###',
0 => '###',
1 => '###',
'datadirectory' => '/mnt/ncdata/company2',
'overwrite.cli.url' => 'https://company2.nextcloud.kz',
'overwritehost' => 'company2.nextcloud.kz',
'dbname' => '###',
'dbhost' => '###',
'dbuser' => '###',
'redis' =>
'host' => '###',
'port' => 6379,
'logfile' => '/var/log/nextcloud/company2-nextcloud.log',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
