Nextcloud version: 13.0.5
Operating system: Shared Hosting (Debian)
Apache version: Apache/2.4.25 (Debian)
PHP version: 7.2.5
Internet accounts preference pane claims it is Unable to verify account or password
I have Little Snitch and when I want to add the account, it warns me twice that there is an outbound connection to my server. The URL seems weird…
Is this the first time you’ve seen this error?: No.
- Trying to connect my NC calendar to my MacOS calendar.
- Copy Paste the iOS/OS X CalDav address
- Click “Sign In”.
No logs created...
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'cloud.mydomain.com',
'datadirectory' => '/domains/mydomain.com/cloud/data',
'overwrite.cli.url' => 'http://cloud.mydomain.com',
'version' => '13.0.5.2',
'dbname' => 'mydomain_com_cloud',
'dbhost' => 'mydomain20.sql.hoster.net',
'dbuser' => 'USER',
'dbpassword' => 'PASSWORD',
'theme' => '',
'loglevel' => 2,
'updater.secret' => '$xxxxx',
Do not have this.
All other Nextcloud functionality works fine and I am also able to add calendars to my Android phone.
