example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.0.1
Operating system and version (eg, Ubuntu 20.04): Linux bullraspi 6.1.21-v8+
Apache or nginx version (eg, Apache 2.4.25): 2.4.56
PHP version (eg, 7.4): 8.1.21
Firefox browser version 116.0 used to login from two different Android phones - works fine on one phone but the other phone returns to login page without logging in.
Is this the first time you’ve seen this error? (Y):
- Launch Firefox on Android phon
- Enter Nextcloud URL
- Enter login information
PASTE HERE
'instanceid' => 'ocf7jxn61vvj',
'passwordsalt' => 'PFdneMiqBV3NM/V+ZczRWgvFAE8R8Z',
'secret' => '/2z40Fs7PuPC2p1t3m9wsoUddWtU0MsKIooTlKBNna44b/WX',
0 => '??????????????',
'datadirectory' => '/mnt/external/nextcloud/data',
'version' => '27.0.1.2',
'overwrite.cli.url' => '?????????',
'dbname' => 'nextclouddb',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => '???????',
'preview_max_x' => 512,
'preview_max_y' => 512,
'jpeg_quality' => 60,
'theme' => '',
'loglevel' => 0,
'app_install_overwrite' =>
0 => 'duplicatefinder',
'memories.exiftool' => '/var/www/nextcloud/apps/memories/exiftool-bin/exiftool
-aarch64-glibc',
'memories.vod.path' => '/var/www/nextcloud/apps/memories/exiftool-bin/go-vod-a
arch64',
'memories.gis_type' => 1,
PASTE HERE
PASTE HERE
PASTE HERE
