@JasonBayton Any luck in identifying the problem. @ksteinb
We’re not paid technical support @Madanmohan_Hassan and you’ve not provided enough info for us to give you a solution. If it works for your local NC DB then there’s no problem with the Nextcloud install, it will be environmental.
Work with your teams to get more logs, monitor the network for login attempts, get logs from the remote DB, etc.
Paid support is available if you need it, otherwise you’ll need to help us help you.
