today I recognized, that I cannot aces my nextcloud server anymore. This is the case from outside the local network and from inside. I can aces other services (subsonic) without any problems.
The server is running since the beginning of this year without any problems. In the nextcloud log there are level 3 and 4 errors listet due to movements of files while syncinc as far as I understood. Can anybody tell me how to get this solved?
Edit:
sudo -u www-data php /var/www/html/nextcloud/occ status
leads to:
- installed: true
- version: 15.0.2.0
- versionstring: 15.0.2
- edition:
Thank you very much!
Nextcloud version 15.0.2
Operating system and version Ubuntu 18.04.3 LTS
Apache or nginx version Apache/2.4.29
PHP version 7.2.19
The last 5 lines output of Nextcloud log in Admin > Logging:
{"reqId":"T8lg2DGjcFiZzWVy85OO","level":3,"time":"2019-10-12T06:45:09+00:00","remoteAddr":"192.168.2.1","user":"gerwern","app":"no app in context","method":"PUT","url":"\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"expected filesize 2461425 got 1818624","Code":0,"Trace":[{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["74 Roskilde 05. September 2019.jpg",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D\u00e4nemark\/74 Roskilde 05. September 2019.jpg",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https:\/\/ServerName/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Server.php","line":301,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/remote.php","line":163,"args":["\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php"],"function":"require_once"}],"File":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":200,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows) mirall\/2.6.0stable-Win64 (build 20190927) (Nextcloud)","version":"15.0.2.0"}
{"reqId":"T8lg2DGjcFiZzWVy85OO","level":4,"time":"2019-10-12T06:45:09+00:00","remoteAddr":"192.168.2.1","user":"gerwern","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"expected filesize 2461425 got 1818624","Code":0,"Trace":[{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["74 Roskilde 05. September 2019.jpg",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D\u00e4nemark\/74 Roskilde 05. September 2019.jpg",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https:\/\ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/files\/gerwern\/Fotos\/2019_UrlaubeUndFeiern\/04_Urlaub-D%C3%A4nemark\/74%20Roskilde%2005.%20September%202019.jpg","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Server.php","line":301,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/remote.php","line":163,"args":["\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php"],"function":"require_once"}],"File":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":200,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows) mirall\/2.6.0stable-Win64 (build 20190927) (Nextcloud)","version":"15.0.2.0"}
{"reqId":"GFXmp1i4eKgAE1YSYTYW","level":3,"time":"2019-10-12T06:59:52+00:00","remoteAddr":"192.168.2.1","user":"gerwern","app":"no app in context","method":"MOVE","url":"\/remote.php\/dav\/uploads\/gerwern\/2067144726\/.file","message":{"Exception":"OCP\\Lock\\LockedException","Message":"\"files\/66af3a80bdc635122901058cfe3ee5f4\" is locked","Code":0,"Trace":[{"file":"\/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Common.php","line":778,"function":"changeLock","class":"OC\\Lock\\DBLockingProvider","type":"->","args":["files\/66af3a80bdc635122901058cfe3ee5f4",2]},{"file":"\/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php","line":615,"function":"changeLock","class":"OC\\Files\\Storage\\Common","type":"->","args":["files\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat",2,{"__class__":"OC\\Lock\\DBLockingProvider"}]},{"file":"\/var\/www\/html\/nextcloud\/lib\/private\/Files\/View.php","line":1964,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":["files\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat",2,{"__class__":"OC\\Lock\\DBLockingProvider"}]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/Node.php","line":359,"function":"changeLock","class":"OC\\Files\\View","type":"->","args":["\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat",2]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","line":219,"function":"changeLock","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->","args":[2]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php","line":316,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["Lightroom 5 Catalog.lrcat",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php","line":130,"function":"copyNode","class":"Sabre\\DAV\\Tree","type":"->","args":[{"__class__":"OCA\\DAV\\Upload\\FutureFile"},{"__class__":"OCA\\DAV\\Connector\\Sabre\\Directory"},"Lightroom 5 Catalog.lrcat"]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php","line":161,"function":"copy","class":"Sabre\\DAV\\Tree","type":"->","args":["uploads\/gerwern\/2067144726\/.file","files\/gerwern\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat"]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Upload\/ChunkingPlugin.php","line":77,"function":"move","class":"Sabre\\DAV\\Tree","type":"->","args":["uploads\/gerwern\/2067144726\/.file","files\/gerwern\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat"]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Upload\/ChunkingPlugin.php","line":56,"function":"performMove","class":"OCA\\DAV\\Upload\\ChunkingPlugin","type":"->","args":["uploads\/gerwern\/2067144726\/.file","files\/gerwern\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat"]},{"function":"beforeMove","class":"OCA\\DAV\\Upload\\ChunkingPlugin","type":"->","args":["uploads\/gerwern\/2067144726\/.file","files\/gerwern\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat"]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"OCA\\DAV\\Upload\\ChunkingPlugin"},"beforeMove"],["uploads\/gerwern\/2067144726\/.file","files\/gerwern\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat"]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php","line":633,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["beforeMove",["uploads\/gerwern\/2067144726\/.file","files\/gerwern\/LightroomArbeitsordner\/Lightroom 5 Catalog.lrcat"]]},{"function":"httpMove","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/2067144726\/.file","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpMove"],[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/2067144726\/.file","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:MOVE",[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/2067144726\/.file","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/2067144726\/.file","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Server.php","line":301,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/remote.php","line":163,"args":["\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php"],"function":"require_once"}],"File":"\/var\/www\/html\/nextcloud\/lib\/private\/Lock\/DBLockingProvider.php","Line":271,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows) mirall\/2.6.0stable-Win64 (build 20190927) (Nextcloud)","version":"15.0.2.0"}
{"reqId":"4IFXgEPlq9hcyQQBv66I","level":3,"time":"2019-10-12T07:00:10+00:00","remoteAddr":"192.168.2.1","user":"gerwern","app":"no app in context","method":"PUT","url":"\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"expected filesize 23333079 got 16334848","Code":0,"Trace":[{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Upload\/UploadFolder.php","line":39,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["00000004",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["00000004",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["uploads\/gerwern\/60407603\/00000004",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Server.php","line":301,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/remote.php","line":163,"args":["\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php"],"function":"require_once"}],"File":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":200,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows) mirall\/2.6.0stable-Win64 (build 20190927) (Nextcloud)","version":"15.0.2.0"}
{"reqId":"4IFXgEPlq9hcyQQBv66I","level":4,"time":"2019-10-12T07:00:10+00:00","remoteAddr":"192.168.2.1","user":"gerwern","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"expected filesize 23333079 got 16334848","Code":0,"Trace":[{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Upload\/UploadFolder.php","line":39,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["00000004",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["00000004",null]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["uploads\/gerwern\/60407603\/00000004",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"\/var\/www\/html\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https:\/\/ServerName\/remote.php\/dav\/uploads\/gerwern\/60407603\/00000004","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Server.php","line":301,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"\/var\/www\/html\/nextcloud\/remote.php","line":163,"args":["\/var\/www\/html\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php"],"function":"require_once"}],"File":"\/var\/www\/html\/nextcloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":200,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows) mirall\/2.6.0stable-Win64 (build 20190927) (Nextcloud)","version":"15.0.2.0"}
'instanceid' => 'XXXX',
'passwordsalt' => 'XXXX',
'secret' => 'XXXX',
0 => 'xyzy.com',
'datadirectory' => '/mnt/storage/nextcloud',
'version' => '15.0.2.0',
'overwrite.cli.url' => 'https://xyzy.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXX',
'twofactor_enforced' => 'false',
'mail_from_address' => '',
'mail_smtpmode' => 'smtp',
'mail_domain' => '',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.gmx.net',
'mail_smtpport' => '587',
'mail_smtpname' => '',
'mail_smtppassword' => '',
The output of your Apache log in /var/log/apache2
[Sat Oct 12 06:25:01.705455 2019] [mpm_prefork:notice] [pid 1402] AH00163: Apache/2.4.29 (Ubuntu) Op$
[Sat Oct 12 06:25:01.705470 2019] [core:notice] [pid 1402] AH00094: Command line: '/usr/sbin/apache2'
[Sat Oct 12 06:29:26.441551 2019] [authz_core:error] [pid 9306] [client 192.168.2.1:49721] AH01630: $
[Sat Oct 12 07:48:24.936703 2019] [mpm_prefork:notice] [pid 1402] AH00169: caught SIGTERM, shutting $
[Sat Oct 12 07:49:12.433018 2019] [ssl:warn] [pid 1202] AH01909: ServerName/:port:0 server cer$
[Sat Oct 12 07:49:14.225753 2019] [ssl:warn] [pid 1600] AH01909: ServerName/:port:0 server cer$
[Sat Oct 12 07:49:14.235514 2019] [mpm_prefork:notice] [pid 1600] AH00163: Apache/2.4.29 (Ubuntu) Op$
[Sat Oct 12 07:49:14.235581 2019] [core:notice] [pid 1600] AH00094: Command line: '/usr/sbin/apache2'
[Sat Oct 12 08:09:51.511471 2019] [mpm_prefork:notice] [pid 1600] AH00169: caught SIGTERM, shutting $
[Sat Oct 12 08:11:05.140731 2019] [ssl:warn] [pid 1027] AH01909: ServerName/:port:0 server cer$
[Sat Oct 12 08:11:06.122991 2019] [ssl:warn] [pid 1522] AH01909: ServerName/:port:0 server cer$
[Sat Oct 12 08:11:06.133612 2019] [mpm_prefork:notice] [pid 1522] AH00163: Apache/2.4.29 (Ubuntu) Op$
[Sat Oct 12 08:11:06.133686 2019] [core:notice] [pid 1522] AH00094: Command line: '/usr/sbin/apache2'
[Sat Oct 12 08:27:02.324032 2019] [mpm_prefork:notice] [pid 1522] AH00169: caught SIGTERM, shutting $
[Sat Oct 12 08:27:02.437886 2019] [ssl:warn] [pid 2042] AH01909: ServerName/:port:0 server cer$
[Sat Oct 12 08:27:02.493956 2019] [ssl:warn] [pid 2051] AH01909: ServerName/:port:0 server cer$
[Sat Oct 12 08:27:02.502799 2019] [mpm_prefork:notice] [pid 2051] AH00163: Apache/2.4.29 (Ubuntu) Op$
[Sat Oct 12 08:27:02.502871 2019] [core:notice] [pid 2051] AH00094: Command line: '/usr/sbin/apache2
