I’m new to nextcloud and just in the phase of testing it for the first time. So far everything works fine and I like it. There is a minor issue, though, and I wanted to ask if you know it or if only I have it.
When I click on the integrated help within nextcloud, it doesn’t look good. It is loaded in another “frame” (probably the wrong term here). I think the best way to desribe it is in the form of a screenshot. In this screenshot I have replicated the problem two times:
Nextcloud version: 18.0.0
Operating system and version: FreeBSD 11.3
Caddy webserver
Thanks for any ideas… Kind Regards, airflow
