My nextcloud instance is reachable from example.ddns.com, but not from www.example.ddns.com. I use a ddns provider (no-ip), can that be the issue?
Web server is nginx, error message is: “page not found”
here is my config:
server {
listen 80 default_server;
server_name example.ddns.net www.example.ddns.net;
root /var/www;
location ^~ /.well-known/acme-challenge {
proxy_pass http://127.0.0.1:81;
proxy_redirect off;
location / {
# Enforce HTTPS
# Use this if you always want to redirect to the DynDNS address (no local access).
return 301 https://$server_name$request_uri;
# Use this if you also want to access the server by local IP:
#return 301 https://$server_addr$request_uri;
server {
listen 443 ssl http2;
..... ssl stuff and so on
location ^~ /nextcloud {
# Set max. size of a request (important for uploads to Nextcloud)
client_max_body_size 10G;
# Besides the timeout values have to be raised in nginx' Nextcloud config, these values have to be r$
proxy_connect_timeout 3600;
proxy_send_timeout 3600;
proxy_read_timeout 3600;
send_timeout 3600;
proxy_buffering off;
proxy_request_buffering off;
proxy_max_temp_file_size 1024m;
proxy_set_header Host $host;
proxy_pass http://127.0.0.1:82;
proxy_redirect off;
Thank you
