Hi, im a software tester and home coder who has a couple of raspberry pis. I have setup asterisk voip and was looking for a new project i found home automation. And now if there is a home call karin (my home assistant) will say that there is a new caller.
But i want to lookup the name of the caller. Home assistant has a sql sensor so with a good sql query and some coding i could get it done.
But i find no easy way to sync for example my phone data to a sql database.
In a facebook group i asked this question. Some one came with this url https://apps.nextcloud.com/apps/contacts
Can i install nextcloud on a raspberry pi4 using dockers with a external database Or with sql access?
Im not very comfortable with dockers.
