example
longer
example
here
Nextcloud version (eg, 20.0.5): 19.0.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 16.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.18 (Ubuntu)
PHP version (eg, 7.4): 7.4
Installation dead, due to following error:
Error: Call to undefined function OC\App\simplexml_load_file() at /var/www/nextcloud/lib/private/App/InfoParser.php#65 2021-04-08T22:30:49+00:00
Note that I have uninstalled and re-installed php-simplexml and php-xml and checked all version numbers (7.4)
- sudo -u www-data php occ log:watch
- access any nextcloud page with browser
NO ACCESS
'debug' => true,
'instanceid' => 'xxxxxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxx',
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxx',
0 => 'rednoise.org',
'overwrite.cli.url' => 'https://server/nextcloud',
'version' => '19.0.0.12',
'dbname' => 'xxxxxxxxxxxxx',
'dbhost' => 'localhost',
'dbuser' => 'xxxxxxxxxxxxx',
'dbpassword' => 'xxxxxxxxxxxxx',
'mail_from_address' => 'xxxxxxxxx',
'mail_smtpmode' => 'php',
'mail_smtpauthtype' => 'xxxxx',
'mail_domain' => 'xxxxxxxx',
'data-fingerprint' => 'xxxxxxxxxxxxx',
'loglevel' => 2,
58.153.66.116 - - [08/Apr/2021:18:37:00 -0400] "GET /nextcloud/ HTTP/1.1" 500 644 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:87.0) Gecko/20100101 Firefox/87.0"
58.153.66.116 - daniel [08/Apr/2021:18:37:13 -0400] "GET /nextcloud/status.php HTTP/1.1" 200 3684 "-" "Mozilla/5.0 (Macintosh) mirall/2.3.3 (build 84) (Nextcloud)"
