Nextcloud version (eg, 10.0.2): 12.0.4
Operating system and version (eg, Ubuntu 16.04): Docker Alpine linux
Apache or nginx version (eg, Apache 2.4.25): nginx/1.13.5
PHP version (eg, 5.6): 7.1.0
Is this the first time you’ve seen this error?: Have it since a few days
Can you reliably replicate it? (If so, please outline steps):
When trying to use any app or non browser to test connecting to the server, I seem to get an infinite loop in http redirects. The nginx log is when I use qualys ssl test to connect to the server, it works fine, except the http request has a loop in it.
The output of your Nextcloud log in Admin > Logging: None
'datadirectory' => '/data',
'apps_paths' =>
0 =>
'path' => '/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/nextcloud/apps2',
'url' => '/apps2',
'writable' => true,
'instanceid' => 'xxx',
'passwordsalt' => xxx',
'secret' => xxx',
0 => 'nextcloud.domain.tld',
'overwrite.cli.url' => 'https://nextcloud.domain.tld',
'version' => '12.0.4.3',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb',
'mail_from_address' => 'administrator',
'logdateformat' => 'Y-m-d H:i:s',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'mail_smtpmode' => 'php',
'loglevel' => 2,
'theme' => '',
'trusted_proxies' => ['172.17.0.0/16'],
172.17.0.10 - - [16/Dec/2017:20:30:06 +0100] "GET / HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Firefox/45.0"
172.17.0.10 - - [16/Dec/2017:20:30:07 +0100] "GET /login HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Firefox/45.0"
172.17.0.10 - - [16/Dec/2017:20:30:08 +0100] "GET /login HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Firefox/45.0"
172.17.0.10 - - [16/Dec/2017:20:30:09 +0100] "GET /login HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Firefox/45.0"
172.17.0.10 - - [16/Dec/2017:20:30:10 +0100] "GET /login HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Firefox/45.0"
