Hi all! I really need help!!!
After updating to Nextcloud Hub 8 (30.0.0 RC1), an error occurred: the folder with files in the web interface and in WebDav is displayed with a size of n-mb. When opening a folder, the files are not displayed. The occ files:scan --all command did not give any results. The log file is also empty. LAMP stack, Ubuntu 22.04.
I really need help, I couldn’t find anything on the forum.
I’m sorry why do you upgrade to a pre-release software when you have no clue how to solve problems and how do you expect help if you don’t care about topic rules and ignore the required support template
Same here on the first stable release of NC30 (deployed via docker image nextcloud/nextcloud:30.0.0 and mysql:8.4)
In my case the problem only occures when I visit the web interface with Microsoft Edge browser, all other tested browsers (Safari (Mac and iPhone), Arc, Firefox) the web interface works fine. Logs also empty, so its hard to get an idea where to search for problems…
Are there known issues with NC30 and Microsoft Edge?
