Nextcloud Hub 35.0.2 (AIO): all apps in top navigation bar, and Talk summary/transcription questions
I run Nextcloud Hub 26 Summer (35.0.2) installed with Nextcloud AIO (Docker) on a Debian VPS. I have two questions.
  • Nextcloud Server version: 35.0.2 (Nextcloud Hub 26 Summer, AIO v14.3.0)
  • Operating system and version: Debian GNU/Linux 13 (trixie)
  • Web server and version: Apache 2.4 inside the nextcloud-aio-apache container (the apache2 binary is not on the container PATH, so the exact version was not retrieved)
  • Reverse proxy and version: Caddy v2.11.7
  • PHP version: 8.4.27
  • Is this the first time you’ve seen this error? Yes
  • When did this problem seem to first start? Around 22 October 2026, when the Call Summary Bot was first tested on a recorded call
  • Installation method: Nextcloud AIO (Docker)
  • Are you using Cloudflare, mod_security, or similar? No
  1. Top navigation bar: only some apps appear in the top bar. I cannot find an admin or personal setting to keep all apps permanently visible. The navigation settings only allow choosing the default app and the fallback priority order.
  2. Talk recordings: recordings save correctly as .webm in the recording folder of the user who started the call. Recordings are not shared with other participants automatically. Speech-to-text works on .m4a files, but the three-dots menu shows no AI option for .webm files.
  3. Call Summary Bot: on a recorded call the task fails with No result in OpenAI/LocalAI response. It persisted after changing the model to another instruction model and raising max tokens to 20000. A later run logged “task succeeded but listener failed to write the result file” from the Assistant app.
  1. Start a Talk call with recording enabled, speak for about 2 minutes, end the call.
  2. Wait for the summary and check the recording folder for a ... - summary.md file.
  3. Check nextcloud.log for TaskProcessing entries.
Log entries (Nextcloud):
{"level":2,"app":"no app in context","message":"Failed to process a TaskProcessing task with synchronous provider integration_openai-text2text","exception":{"Exception":"OCP\\TaskProcessing\\Exception\\ProcessingException","Message":"No result in OpenAI/LocalAI response."}}
{"level":2,"message":"A TaskProcessing core:text2text task failed with the following message: No result in OpenAI/LocalAI response."}
{"level":3,"app":"assistant","message":"FileActionTaskListener task succeeded but listener failed to write the result file","exception":{"Exception":"OCP\\Files\\NotPermittedException"}}
Web Browser: Not applicable for items 2 and 3. For item 1, nothing to report.
Web server / Reverse proxy: Not requested at this stage; available on request.
Configuration (Nextcloud):
"version": "35.0.2.2"
"dbtype": "pgsql"
"overwriteprotocol": "https"
"memcache.distributed": "\\OC\\Memcache\\Redis"
"twofactor_enforced": "true"
"AIO_VERSION": "v14.3.0"
(Sensitive values removed.)
Apps:
spreed 25.0.6, call_summary_bot 3.5.0, integration_openai 5.0.0, assistant 4.0.0, workflowengine 3.0.0, files_sharing 2.0.0
thanks a lot
hey @peio-code! nice that you found your way to the community-forum of NC.
I have some questions
  • do you have anything like custom-menu app (or similar) installed?
  • how did you install your local AI-agent (I#m especially asking b/c you seem to run AIO in a beta-version)
Hi Jimmy and thanks
no i haven’t installed such app. should I ?
i installed me AI just with OVH public cloud. i am not running beta, am I ?
Pierre
no. not necessarily. I was just wondering about your sentence
because usually you have this “new” waffle menu - which got introduced with NC34. if you’d open one of the apps from there it’ll show only this app in the top bar (and maybe a 2nd one, I’m not sure since I don’t run that)
that doesn’t tell me anything.
But running AIO you should read AIO’s installing suggestions, especially regarding how to install local AI
ahh ok ok it’s found this new waffle not ideal… but ok
For local IA yes i follow the process and it works most of the time
if you don’t like it → Custom menu - Apps - App Store - Nextcloud
