Hello, I have 2 exactly the same Nextcloud VMs running on different hardware.
The following difference is extremely noticeable:
Nextcloud 1: CPU average load 0 (idle)
Nextcloud 2:
Average CPU utilization 0.6
The biggest difference, however, is when using the Nextcloud. If you click around a bit and work something with Nextcloud, the load on Nextcloud 1 goes up to about 1.1
With Nextcloud 2 it runs at 2.8 …
The Nextcloud 2 is also much slower than the Nextcloud 2, why is this? …
