Nextcloud help fix Error?
Hi everyone. I have configured the next cloud and this error constantly appears in the log
“Exception: The requested uri(/data/.ocdata) cannot be processed by the script ‘/nextcloud/index.php’)” what can it be? advise where to look and how to fix it?
Post the log
https://pastebin.com/GAnW4ufy
Make sure that the mentioned .ocdata file exists in your data folder and that it is accessible. See also:
What is your configured data directory? That is in your config/config.php file:
‘datadirectory’ => ‘???’
Does it just say ‘/data’ here? It should be the full path, like ‘/var/www/html/nextcloud/data’.
What are the unix access privileges of that path? It should be the owner of the webserver process, like www-data for apache.
What is your operating system?
image_2019-09-03_20-00-13
Operating system : Ubuntu Server 18.04.3 LTS
Can you please use the following command and post the result? (if there are any folders with usernames, you can blank them out)
ls -lah /var/www/html/nextcloud/data
Still, what is the content of your config file?
Here is the output of the command:
photo_2019-09-06_09-43-20
config/config.php
photo_2019-09-06_09-43-18 photo_2019-09-06_09-43-16
As we can see the file exists and has the proper permissions, so it must be something else causing this issue.
Please could you change the value of overwrite.cli.url in your config.php to the following:
http://192.168.1.11/nextcloud/
Now keep an eye on your log file and see if the error keeps appearing.
so overwrite.cli.the url is already written:
What else could be the problem?
Sorry for the late reply, was a little busy lately.
Please could you execute the following command via SSH and post the output in here?
Command:
#: cd /var/www/html/nextcloud && sudo -u www-data php occ app:list
This should list the apps you have enabled and disabled. Maybe there is something not quite right with one of the apps :thinking:
