Nextcloud version (eg, 20.0.5): 23.0.0
Operating system and version (eg, Ubuntu 20.04): 20.04.3 LTS
Apache or nginx version (eg, Apache 2.4.25): 2.4.41
PHP version (eg, 7.4): 8.0
So I’ve been running Nextcloud for a few days now and I’ve noticed that the web-interface is extremely slow to load, it can sometimes easily take 5-10 seconds to load and then switching apps or pages similarly long whereas other services I run on that server that use large databases (Gitea) load much quicker especially with Apache caching enabled.
I have php-fpm, apcu, redis locking and opcache all enabled and this issue still persists.
I have also verified from the other thread about this that I found that IPv6 is working as intended.
My server specs are:
Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz (2 cores)
2gb of RAM
Gigabit Networking
This seems abnormally slow and I don’t really feel like any content is actually being cashed as these loading times persist through reloads however from everything I can tell the APCu and Redis cache are working as intended, at least there are no errors regarding it to be found.
If there’s any more info you need I’ll be happy to provide it!
'instanceid' => 'XX',
'passwordsalt' => 'XX',
'secret' => 'XX',
0 => 'nextcloud.example.com',
'datadirectory' => '/home/nextcloud/nextcloud-data',
'version' => '23.0.0.10',
'overwrite.cli.url' => 'https://nextcloud.example.com',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'XX',
'twofactor_enforced' => 'true',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => 'in-v3.mailjet.com',
'mail_smtpport' => '25',
'mail_domain' => 'example.com',
'mail_smtpauth' => 1,
'mail_smtpname' => 'XX',
'mail_smtppassword' => 'XX',
'redis' =>
'port' => 0,
'defaultapp' => 'files',
'loglevel' => 2,
My Apache2 virtualhost config:
<VirtualHost *:80>
ServerName nextcloud.example.com
RewriteEngine on
RewriteCond %{SERVER_NAME} =nextcloud.example.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/nextcloud.example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nextcloud.example.com/privkey.pem
# enable HTTP/2, if available
Protocols h2 http/1.1
# HTTP Strict Transport Security (mod_headers is required) (63072000 seconds)
Header always set Strict-Transport-Security "max-age=63072000"
DocumentRoot /var/www/html/nextcloud/
ProxyPreserveHost On
ProxyRequests Off
<Directory /var/www/html/nextcloud/>
Require all granted
AllowOverride All
Options +FollowSymLinks
Options MultiViews
<IfModule mod_dav.c>
Dav off
</IfModule>
</Directory>
</VirtualHost>
# modern configuration
SSLProtocol all -SSLv3 -TLSv1 -TLSv1.1
SSLHonorCipherOrder off
SSLSessionTickets off
SSLUseStapling On
SSLStaplingCache "shmcb:logs/ssl_stapling(32768)"
