the forum is still very slow for me, here in The Netherlandsā¦
hope something can be done about it
Thatās strange Iām in the Netherlands too but it isnāt slow at all for me
For me it is browser based.
Los Angeles California
Firefox = very slow
Chrome = works
Safari = slow
soon =
Itās nothing to do with your location, or your browser. Itās simply the MRU of your internet link. If your path to the internet is a full 1500 all the way out, you wonāt have a problem. If itās less than 1500, then youāre in for pain, as something is broken in the IP stack somewhere at the help.nextcloud.com end of the path. The server is ignoring the mss advertised in the syn packet at the start of each conversation, AND it is ignoring all the ICMP frag needed packets being sent back by your upstream router. Iāve raised this multiple times, but the forum admins donāt seem to care. I guess itās working for them, so bugger everyone whoās on PPPOE connections? (aka 50+% of australia, and large parts of the EU?)
It should be trivial to fix, either see what on earth bizarre settings someone has tweaked in the linux kernel or iptables on the server help.nc is hosted on, and fix them, or just shove it behind cloudflare.
I tested with MTU size of 1200 and the forum is fast for me now. Definitely not the fastest in the world but initial load with empty cache is 2.5s and reload of 1.2s sounds good for me.
I donāt see any difference changing MTU from 1480 to 1200 and back (verified MTU change applied with ping help.nextcloud.com -f -l 1200 -n 1
) packet size without fragmentation is always 28 bytes smaller than my computerās MTU, for tested MTU sizes of 1480 and 1200ā¦
Iām normally in New Zealand but presently in Colombia. We have great internet here - speeds circa 600gb/s. Loading this site this morning took over 7 minutes - just in case anyone thinks itās fixed.
Given the recent advertising (or perhaps suggestion) that next cloud is becoming a true alternative to other 365 style apps - Iād say this should be a very high priority to fix as no one will take a company seriously that canāt even get itās forums to work.
I agree with you itās a high priority, itās a very tough nut to crack which is why we donāt have a timeline but we are not giving up.
I agree with the previous poster. Cloudflare has some fantastic free options available and would be night and day difference if that could be utilised. Unless thereās some architectural reason to use another product such as developing on Amazon and using their cdn to be practical, cloudflare is leading this space far beyond what others are doing and would be a great choice.
Test with GTMetrics (from Canada), fully load > 25 s:
some fonts are missing
do you really need a cookie with 3 MB? (firefox) to track me
again: large images in teaser
looks your POST poll
with 251 bytes to help.nextcloud.com
takes agesā¦
everything else is same as in Europeā¦
Iām pretty sure your assumption about cookies is wrong. the FF dialog you are referring to show a total size of cookies,cache, etc, in my case:
but cookies are only few bytes
Iām in Australia and pages dont even load at all any more. Been like that for months.
As a work around I use a Proton VPN account connected to the Netherlands. Then pages load like any other website.
Really hope the admins can sort this out soon.
Yeah, this is really sloppy and reflects poorly on Nextcloud.
It looks like @rendrag has presented a good analysis of the problem, not good enough for this problem to be persisting so long.
I also note that the issue that @tflidd posted is now an archived repository, so probably needs to be reopened.
Sorry to hear youāre facing problems
Community discourse instance can not be opened from Australia, or takes minutes to load.
If accessed from the main page https://help.nextcloud.com/ then it can hardly be opened even after several minutes it is still loading with five dots.
No adblock is turned on for this site.
If luck, sometimes the website can be opened within like 10 seconds or so, so I can register and post this. But most of the time it can not be opened.
I donāt see any waf challenge. Only thing showing is the five dots and takes many minutes still can not be opened.
Tried to open it through digital ocean vps in sydney , same result.
Browser is Chrome /Firefox /edge.
More test:
broadband with google/cloudflare dns, can not open;
vpn into digital oceanās sydney vps ip+cloudlare dns, can not open.
mobile network: fast access no issue.
vpn into europe country: fast access no issue.
So the issue could be the broadband Iām using?
Tracert on mobile network: (works)
Tracert on broadband:
Is this the first time youāve seen this error? (Y/N):N
- access from Australia down under
@prefix3826 I moved your port into this thread as it seems to be same issue as the one from @tetra
It looks general performance of the forum improved and users in Europe donāt hit many issues anymore. As accessing the forum works through VPN and mobile it must be related to network - I have no idea what could be special in Australia but it looks the issue affects many/multiple users.
additionally it is very uncommon latency jumps 240ms on one hop within network of one provider - from the hostname sounds itās still in AU - and this 240ms are 4 times more then the remaining ālongā way to Europe which add āonlyā 50ms - this should not happen - one would expect latency to increase when going overseas but not even such huge differenceā¦ I would ask your provider if they can double check this hopā¦
Thanks.
VPN into Singapore also no issue, loads in 2 seconds.
Itās just my broadband almost never opens the website.
But what about I donāt have any issue with nextcloud.com or any other website?
Only the combination of my broadband + the help.nextcloud.com forum together causing issue.
Ane read from this thread, it seems not only users from Australia, there are other users from other countires also have similar issue.
So Iād think the server/site configration with some kind of broadband structure/configaration together caused the issue. It is not limited to some particular broadband provider in Australia.
For the big latency jumps, yes it looks like it is within the same cityās two points. Usual ping between two computers should be less than 10ms within the city, and ping from Brisbane to Sydney should be less than 20ms, but those are out of the userās reach.
I think it might be related to the CDN service the site is using.
After the .js and .css has been loaded and cached on local disk/memory, then
opening the homepage or link wonāt be a problem any more.
(I have to first load the js and css via vpn link, then exit vpn works).
If I try to load via incogniziton window or clear cache, then it wonāt work anymore.
Compare the CDN service for help.nextcloud.com and nextcloud.com to see any difference.
I am in Singapore. I have different experience for help.nextcloud.com in different days.
And same as apps.nextcloud.com, looks it is not a CDN related issue as I never clear my cache, but I hit multiple times in a week it took more than 10s to open help.nextcloud.com threads or got timeout to load the app list from apps.nextcloud.com. After a while, it become faster again.
Iāve no issue with https://apps.nextcloud.com/ or nextcloud.com.
10s should be considered as network congestion instead of a real issue that is original from help.nextcloud.com server/cdn
good point.
In theory we have to check the way back as well. For you it is just the routing from your home to help.nextcloud.com, but the data are sent from help.nextcloud.com to your ip that might take a different route.
It can happen that between the networks (peering), sometimes the connections are saturated. In theory, they should manage to handle this, taking different routes and upgrading peering connections.
Another problem is that within each operator, they can prioritize/filter packages with criteria unknown to public.
Will you try curl -o /dev/null --compressed https://help.nextcloud.com/assets/foo
and share the result?
Get the actual URL from the browserās developer tools window, under network. Sort by size and choose the largest asset/resource/file (typically the Discourse Javascript). This is a straightforward repeatable test Iāve been doing for a while now. It is nicely constrained test. It is reliably slow when I am at home and reliably fast most other places I try it.
Hereās a slow example, from just now:
$ resource_url="https://help.nextcloud.com/assets/discourse-fa0bebf654588c3e45c7d642211b1a3a7f39649c44fec50bcbf3317afdb6b976.js"
$ curl -o /dev/null --compressed "$resource_url"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 508k 100 508k 0 0 9617 0 0:00:54 0:00:54 --:--:-- 10344
10KB/s is relatively quite slow.
For your test, if it stalls for you at the beginning (or doesnāt download), thatās useful to know too. Youāll feel that during normal forum use.
