Nextcloud Fortigate Certificate Issue
Running newest version of NextCloud on unraid. This morning both my nextcloud server internet page is being blocked by fortigate. The certificate is invalid. NET::ERR_CERT_AUTHORITY_INVALID
Am I the only one having this issue?
Should I contact Fortigate rather?
Thank you in advance for replies.
In trying to solve your problem, please check if your
  1. Forigate Firewall received an update recently.
  2. Has there been any update (performed) on your nextcloud instance?
  3. Has there been any updates (performed) on the server that runs the NextCloud instance?
  4. Are you using a self-signed certificate on your NextCloud server?
This might put you in a direction to solve your problem.
