Nextcloud Files for MAC installation problems
    • 31.0.8.2
    • MAC26.0
    • not relavant
    • replace me
    • replace me
    • no
    • replace me
    • replace me
    • replace me
Has anyone had installation and file sync issues with Nextcloud Virtual file system on the MAC. We are running a self hosted version of nextcloud and have had issues where the application on the mac cannot connect to the server. When it does file sync does not work. In many cases the files seen on the server do not populate. Files modified on the MAC override files changed on the server web interface. Locking does not work. Also, I now upgraded to 4.0 and it wont even run.
Is this thing stable, does it work at all or do you suggest dumping attempting to sync the virtual file system to a MAC.
Ready to dump nextcloud all togeather. I have never seen so many problems with an app as I do with this VFS MAC application.
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
Does it work for other clients (other OS, mobile clients)? And if you use without VFS? And on the browser of the mac it works I suppose.
Is there a 4.0 version of the desktop client?
For few more pointers for debugging,
There was a 4.0 version temporarily available on the download site but it has been retracted so I am only assuming that Nextcloud is aware of the issues in the new version.
I have been testing with a support person from Nextcloud and it has issues for sync’d folders also. There are numerous lock issues when testing against a cloud instance also. It really needs work.
Is there a github issue? This way, everybody could follow up on this topic.
Not sure yet. Currently I am working with Nextcloud support to identify if this is related to our hosted environment or if there are real issues. This was just an attempt to determine if others are seeing issues with this client and its considered stable.
