Nextcloud.export does not work when called by cron
Nextcloud version: 27.1.9.1 snap version
Operating system and version: Ubuntu 22.04
Apache version: 2.4 according to https://github.com/nextcloud-snap/nextcloud-snap
PHP version: 8.2 according to https://github.com/nextcloud-snap/nextcloud-snap
nextcloud.export doesn’t work when called (in a script) by cron
Is this the first time you’ve seen this error?: Yes
  1. nextcloud.export works
  2. nextcloud.export works in a script when I run the script manually
  3. nextcloud.export doesn’t export anything when the script is called by cron
My root crontab is:
0 */1 * * * /root/backup_nextcloud.sh
BUT I have a second script called run_backup_script.sh. If I call that script with cron, then the nextcloud.export runs beautifully.
cat run_backup_script.sh:
#!/usr/bin/env bash
/root/backup_nextcloud.sh | mail -s "backup output" me@gmail.com
Hope that is clear. The export command works if I run the script manually, but it does not if the script is called from a cronjob. But it DOES if I make another script that calls it. Thanks in advance!
EDIT: I also noticed from the logs that when nextcloud.export is called by crond via a script, the config is not exported. But, again, if the same script is executed manually, the config is exported fine. Here is the message in the log showing the failure:
Exporting config...
Unable to export config
All very mysterious! Maybe it’s my lack of depth of understanding of how crond works…
Hi @cuorie,
assuming you’ve changed the data directory, we’ve seen similar issues.
see also the developers note in code
check out the alternative backup, restore & migrate method. this snap export script is known to work, but the snap snaphot method is recommended,
