does anyone of you also have problems with synchronizing birthdays?
If I set a birthday on my mobile phone or PC, nextcloud does get the contact, but does not include the birthday in it.
Therefore after another synchronization there is no birthday information about that contact on any of my devices.
Does anyone has any ideas how that could be?
Since opensync is a fork of DAVdroid it should work, as it does on my phone. Therefore sorry, but not able to reproduce. Nonetheless if you are experiencing this issue, it may be best to open an issue at the cardbook and/or opensync repo.
Hey,
thank you for your research, even though I saved all my birthdays including years and therefore do not had troubles with that, it did got me another idea.
After I manually said thunderbird to use the format yyyy-mm-dd it worked.
