Guys, I access my NC externally normal, browse the folders and everything.
However, when I open an Onlyoffice file it doesn’t load, locally it opens normal.
Help me please.
installed by snap
ubuntu server 20.04 LTS
Note: I used the Google translator.
Hi, I hope this helps you. This is from my nginx reverse proxy. My onlyoffice document server is in a docker on unRaid 192.168.1.4, my Nextcloud sits in a docker on the same ip, bridged.
They connect through my router running a reverse proxy. This is not the official nginx file from Onlyoffice which I though was a bit lengthy. Mine works 100% from what I can see ( only installed yesterday). I didn’t bother with Community server.
Blockquoteserver {
listen 80;
server_name documents.********.com;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
server_name documents.*******.com;
access_log /opt/var/log/nginx/documents.access.log;
error_log /opt/var/log/nginx/documents.error.log;
client_max_body_size 10G;
underscores_in_headers on;
ssl_certificate /tmp/home/root/.acme.sh/******.com/fullchain.cer;
ssl_certificate_key /tmp/home/root/.acme.sh/******.com/aussiepor >
ssl_stapling on;
ssl_stapling_verify on;
#************Access Control ********************
include /opt/etc/nginx/nginx_whitelist_internal;
location / {
proxy_headers_hash_max_size 512;
proxy_headers_hash_bucket_size 64;
proxy_set_header Host $host;
add_header Front-End-Https on;
# whatever the IP of your cloud server is
proxy_pass http://192.168.1.4:8082;
Thanks for the answer.
I do not use Nginx, I installed it by snap.
I use the apache that was installed automatically by the snap.
on my local network onlyoffice works normal, but on the external network it does not open.
Rafael,
I have no experience with snaps. I tend to use dockers or install manually.
How are you connecting from external? I assume you may have a VPN? I haven’t used Apache since converting to nginx quite a while ago. If its a VPN there may be a network rule that is limiting the VPN network from being recognised.
