i made a new docker container (based on nextcloud:fpm-alpine) which fixes some issues i had:
- /var/www/html as a volume, which means that any external storage is a different mountpoint which leads to very slow file moves (something i need quite often)
- automatic install/enable apps for easier deployment
- redis and mysql connects through a socket and not through tcp/ip. nextcloud is self contained in one container (except nginx)
- as i run nc in a low resource environment there is a nginx reverse proxy which directly connects to php-fpm (and not two)
- sets up cron (also for preview generator)
feel free to use it: https://hub.docker.com/r/flower1024/nextcloud itβs also on github. suggestions are very welcome
