example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud AIO v1.3.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.52 (Ubuntu)
Hi, I have a docker version of nextcloud running on ubuntu 22.04
In the same server i would run an apache reverse proxy (running on port 443) that also redirect to Nextcloud on port 8443 or 8080
when the docker NextCloud aio run, start 2 images
docker run -it --name nextcloud-aio-mastercontainer --restart always -p 81:80 -p 8080:8080 -p 8443:8443 --volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config --volume /var/run/docker.sock:/var/run/docker.sock:ro nextcloud/all-in-one:latest-arm64
the result is that also 443 port is reserved by aio-domaincheck
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ccb44a23bf65 nextcloud/aio-domaincheck:latest-arm64 "/start.sh" 56 seconds ago Up 54 seconds 0.0.0.0:443->443/tcp, :::443->443/tcp nextcloud-aio-domaincheck
a9243b137985 nextcloud/all-in-one:latest-arm64 "start.sh /usr/bin/s…" 2 minutes ago Up 2 minutes 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp, 0.0.0.0:8443->8443/tcp, :::8443->8443/tcp, 0.0.0.0:81->80/tcp, :::81->80/tcp nextcloud-aio-mastercontainer
So i can’t run my apache as reverse proxy.
I can move my apache over an other port but i not would…
Can i disable the domain checker? or move to another port?
Is this the first time you’ve seen this error? Y:
- start aio docker image
- start apache2 that fails to bind on 443 port
