Nextcloud version: 22.2.0
Operating system and version: docker on Linux 5.4.0-80-generic x86_64
Apache: embedded one
PHP version: 8.0.12
The issue you are facing: cannot connect to dav server
Is this the first time you’ve seen this error? (N): I reinstalled nextcloud docker image several times with no success.
- install from docker, create user admin and password
- correctly access nextcloud from web interface
- insert “dav://192.168.1.13:8080/remote.php/dav/files/admin/” in nautilus to connect to dav server
- Error is returned
no interesting logs are shown except some:
OCP\Files\NotPermittedException: Could not create folder
/var/www/html/lib/private/Files/AppData/AppData.php - line 156:
OC\Files\Node\Folder->newFolder("0")
/var/www/html/apps/theming/lib/ImageManager.php - line 156:
OC\Files\AppData\AppData->newFolder("0")
/var/www/html/apps/theming/lib/ImageManager.php - line 171:
OCA\Theming\ImageManager->getCacheFolder()
/var/www/html/apps/theming/lib/Controller/IconController.php - line 90:
OCA\Theming\ImageManager->getCachedImage("icon-core-f ... g")
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 217:
OCA\Theming\Controller\IconController->getThemedIcon("core", "filetypes/folder.svg")
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 126:
OC\AppFramework\Http\Dispatcher->executeController(OCA\Theming\ ... {}, "getThemedIcon")
/var/www/html/lib/private/AppFramework/App.php - line 156:
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Theming\ ... {}, "getThemedIcon")
/var/www/html/lib/private/Route/Router.php - line 301:
OC\AppFramework\App::main("OCA\\Themin ... r", "getThemedIcon", OC\AppFramew ... {}, { app: "core ... "})
/var/www/html/lib/base.php - line 1000:
OC\Route\Router->match("/apps/themi ... g")
/var/www/html/index.php - line 36:
OC::handleRequest()
and
Could not detect any host in https:///data/htaccesstest.txt
