Nextcloud Client Version: 2.3.1
OS: Ubuntu 16.04 LTS
Can you reliably replicate it? (If so, please outline steps):
hey,
I’m running nextcloud for some time now and I wanted to connect to a new user, which have been created on the server. but I can’t find the assistant for that? if I run “nextcloud” in command prompt with --logwindow flag there are only set up connections I can see.
any help please
