Nextcloud 12.0.3
Synology NAS
Apache 2.4
PHP 5.6
Access internal: directly
Access external: via Apache Reverse Proxy
I am facing problems with Collabora Onlineā¦getting the following error in log:
Error richdocuments GuzzleHttp\Exception\ClientException: Client error response [url] https://cloud.mydomain.ch/hosting/discovery [status code] 404 [reason phrase] Not Found
Error internet_connection_check GuzzleHttp\Exception\RequestException: cURL error 60: SSL certificate problem: unable to get local issuer certificate
I give it a try to google, and found suggestions to place SSL cert to path: \nextcloud\resources\config\ca-bundle.crt
anyone facing same problems?
