Hello! Tell me, is it possible to increase the file synchronization speed for the Nextcloud client, since synchronization takes a very long time, provided that - client version 3.15.2, web server - Nginx 1.20.1, Nextcloud - 30.0.4, MariaDB - 10.6.20, operating system - CentOS 9 Stream, data volume 6 TB, number of files - 2502699. Thank you.
Please:
- fill out the support template
- clarify a bit more specifically what aspect of sync performance is below expectations (are you referring to the initial sync? Or ongoing performance after the initial sync?
- quantify what you can a bit with numbers so we have some context (i.e. maybe give a specific example of where you’re seeing unexpected performance)
- if it’s a transfer (uploading/downloading) throughput matter, have you compared performance utilizing the Web UI? That will further provide a baseline to compare for your Nextcloud instance and help isolate whether a Desktop client matter or something elsewhere
If you’re use case truly involves syncing all of these files constantly, please share some context about the typical file size, frequency of changes, apps involved, etc.
Hello! I am more interested in the issue of primary synchronization, after a long count of files on the server, the client creates virtual files one by one, which is not very convenient with a large number of files. For example, synchronization of file 658508 using virtual files took more than 24 hours (I did not count exactly).
PHP-fpm version 8.3.13, pm.max_children = 960
MariaDB - deployed on a separate Hyper-V VM with resources of 24 CPU, 16 RAM
VM deployed on Hyper-V with resources of 32 CPU, 32 RAM
Nginx is preceded by HAproxy version 2.4.22-f8e3218
Below are the server configuration parameters for Nextcloud:
sudo -u nginx php /var/www/nextcloud/occ config:list system
“system”: {
“instanceid”: “REMOVED SENSITIVE VALUE”,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“10.240.60.11”,
“10.240.51.2”,
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “30.0.4.1”,
“overwrite.cli.url”: “http://files.decs.kz”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“chunkSize”: “5120MB”,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “REMOVED SENSITIVE VALUE”,
“port”: 6379
“filelocking.enabled”: true,
“default_phone_region”: “==”,
“maintenance_window_start”: 1,
“log_type”: “file”,
“loglevel”: 3,
“logtimezone”: “Asia/Almaty”,
“ldapProviderFactory”: “OCA\User_LDAP\LDAPProviderFactory”,
“skeletondirectory”: “/var/www/nextcloud/core/userskeleton”,
“maintenance”: false,
“theme”: “”,
“htaccess.RewriteBase”: “/”,
“defaultapp”: “”,
“trashbin_retention_obligation”: “auto”,
“twofactor_enforced”: “false”,
“onlyoffice”: {
“verify_peer_off”: true,
“jwt_secret”: “REMOVED SENSITIVE VALUE”,
“jwt_header”: “AuthorizationJwt”
“upload_max_filesize”: “512M”,
“enable_previews”: true,
“enabledPreviewProviders”: [
“OC\Preview\PNG”,
“OC\Preview\JPEG”,
“OC\Preview\GIF”,
“OC\Preview\BMP”,
“OC\Preview\XBitmap”,
“OC\Preview\MP3”,
“OC\Preview\TXT”,
“OC\Preview\MarkDown”,
“OC\Preview\OpenDocument”,
“OC\Preview\Krita”,
“OC\Preview\PDF”
sudo -u nginx php /var/www/nextcloud/occ app:list
- admin_audit: 1.20.0
- bruteforcesettings: 3.0.0
- comments: 1.20.1
- contactsinteraction: 1.11.0
- dav: 1.31.1
- federation: 1.20.0
- files: 2.2.0
- files_downloadactivity: 1.17.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- group_default_quota: 0.1.10
- groupfolders: 18.0.8
- logreader: 3.0.0
- notifications: 3.0.0
- oauth2: 1.18.1
- onlyoffice: 9.5.0
- password_policy: 2.0.0
- photos: 3.0.2
- previewgenerator: 5.7.0
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- text: 4.1.0
- theming: 2.5.0
- twofactor_totp: 12.0.0-dev
- updatenotification: 1.20.0
- user_ldap: 1.21.0
- viewer: 3.0.0
- workflowengine: 2.12.0
Disabled: - activity: 3.0.0 (installed 3.0.0)
- app_api: 4.0.3 (installed 4.0.3)
- calendar: 5.0.8 (installed 5.0.8)
- circles: 30.0.0 (installed 30.0.0)
- contacts: 6.1.2 (installed 6.1.2)
- dashboard: 7.10.0 (installed 7.9.0)
- encryption: 2.18.0
- files_downloadlimit: 3.0.0 (installed 3.0.0)
- files_external: 1.22.0 (installed 1.21.0)
- files_photospheres: 1.30.0 (installed 1.30.0)
- firstrunwizard: 3.0.0 (installed 2.18.0)
- geoblocker: 0.5.15 (installed 0.5.15)
- suspicious_login: 8.0.0
- user_status: 1.10.0 (installed 1.9.0)
- weather_status: 1.10.0 (installed 1.9.0)
- webhook_listeners: 1.1.0-dev (installed 1.1.0-dev)
