Nextcloud client does not work for MacOs Sonoma
Hello, after ive installed nc client on my mac and seemingly authorised the login via browser the window disapears and is nowhere to be found, if i start next cloud again the same thing happens, i do not see any config files or snything similar, tried reinstalling and restarting, what else could i do?
Solved: I had to completely uninstall nextcloud from my mac, using the Pearcleaner app, tho probably you could do it natively without 3rd party software. Now after reinstalling it works and appears in my dock
Leaving this for anyone who might struggle with this
