If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of the following as you can (you can cut and paste this into your topic):
Nextcloud version (eg, 12.0.0):
Operating system and version (eg, Raspbian jessie with pixel):
PHP version (eg, 7.0):
Is this the first time you’ve seen this error?:
Consistently coming
Can you reliably replicate it? (If so, please outline steps):
yes
Hi, I have checked on my raspberry pi that whenever i cancel a download the TCP socket keeps waiting on the FIN_WAIT2 state which makes the next download speed to get decreased. Is it a problem with nextcloud to not send a FIN packet to let the TCP know that the socket is no longer needed hence it should be closed.? How we can achieve that.?
Remember, this information may be requested if it isn’t supplied; for fastest response please provide as much as you can Feel free to use a pastebin service, otherwise log files can be indented with 4 spaces on each line to present them in a friendlier way on the forum.
