- 31.0.6.3
- Nextcloud client version:
- 4.0.7daily
I am trying to setup nextcloud client via command line on Fedora 43 and the command line client does not seem to work at all.
I am executing the following command which is also written in the nextcloud docu:
nc_config="$HOME/.config/Nextcloud/"
nextcloud --userid "$nc_user" --apppassword "$nc_password" --serverurl "$url" --localdirpath "$nc_path" --confdir "$nc_config" --logdebug
All other variables are read from user input and are correct (if I copy them from the password manager into the GUI, it works).
There is no error being reported but if I check the local path, it is empty and nextcloud is not mounted there. Also the GUI does not show any connection to the server.
Nextcloud (client)
No errors, only a couple of warnings from warning default qrc:/qml/src/gui/tray/*** with TypeError: Cannot read property '<component>' of null. They do not seem to be related
Info/debug messages report the following:
PROPFIND of QUrl("<serverurl>/remote.php/dav/files/<user>/") FINISHED WITH STATUS "OK"
Saved all account settings, status: QSettings::NoError
So, how do I setup nextcloud client via command line? I would like to do this for multiple computers, so I would like to avoid setting up everything manually.
Thanks very much for help! ![]()
