Hi guys. I really don’t know what is wrong here, but Nextcloud CLI (server-side) doesn’t work for me?
Serever info:
- Nextcloud version ( 10.0…0)
- Operating system and version (Ubuntu 14.04)
- Apache or nginx version (Apache 2.4.7)
- PHP version (5.5.9):
I can see the problem is with my connection to my DB which is on a separate server (Mysql/MariaDB) but everythinig except CLI seems to work just fine for me
terminal output of sudo -u www-data php occ files:scan
exception 'Doctrine\DBAL\DBALException' with message 'Failed to connect to the database: An exception occured in driver: could not find driver' in /var/www/owncloud/lib/private/DB/Connection.php:59
Stack trace:
#0 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/owncloud/lib/private/DB/Connection.php(142): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/owncloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/owncloud/lib/private/DB/ConnectionFactory.php(123): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /var/www/owncloud/lib/private/Server.php(415): OC\DB\ConnectionFactory->getConnection('mysql', Array)
#8 /var/www/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#9 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet('DatabaseConnect...')
#10 /var/www/owncloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query('DatabaseConnect...')
#11 /var/www/owncloud/lib/private/Server.php(1029): OC\ServerContainer->query('DatabaseConnect...')
#12 /var/www/owncloud/lib/private/Server.php(220): OC\Server->getDatabaseConnection()
#13 /var/www/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#14 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet('OC\\Authenticati...')
#15 /var/www/owncloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query('OC\\Authenticati...')
#16 /var/www/owncloud/lib/private/Server.php(224): OC\ServerContainer->query('OC\\Authenticati...')
#17 /var/www/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#18 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet('OC\\Authenticati...')
#19 /var/www/owncloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query('OC\\Authenticati...')
#20 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(151): OC\ServerContainer->query('OC\\Authenticati...')
#21 /var/www/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(109): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#22 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet('OC\\Authenticati...')
#23 /var/www/owncloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query('OC\\Authenticati...')
#24 /var/www/owncloud/lib/private/Server.php(239): OC\ServerContainer->query('OC\\Authenticati...')
#25 /var/www/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#26 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet('UserSession')
#27 /var/www/owncloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query('UserSession')
#28 /var/www/owncloud/lib/private/Server.php(906): OC\ServerContainer->query('UserSession')
#29 /var/www/owncloud/lib/private/Server.php(459): OC\Server->getUserSession()
#30 /var/www/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#31 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(103): Pimple\Container->offsetGet('AppManager')
#32 /var/www/owncloud/lib/private/ServerContainer.php(89): OC\AppFramework\Utility\SimpleContainer->query('AppManager')
#33 /var/www/owncloud/lib/private/Server.php(1206): OC\ServerContainer->query('AppManager')
#34 /var/www/owncloud/lib/private/legacy/app.php(293): OC\Server->getAppManager()
#35 /var/www/owncloud/lib/private/legacy/app.php(109): OC_App::getEnabledApps()
#36 /var/www/owncloud/lib/base.php(642): OC_App::loadApps(Array)
#37 /var/www/owncloud/lib/base.php(1043): OC::init()
#38 /var/www/owncloud/console.php(48): require_once('/var/www/ownclo...')
#39 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
