Hey every interested and maybe helping person,
After the presentation of NC 22 and the possibillity to use ressources in the calendar app I installed an Nextcloud 22.1.0 on Ubuntu 20.04 TLS with apache2 and PHP 7.4.
I set up everything to find out, that the normal instanz of nextcloud don’t support the ressources yet. I found the app on github (GitHub), so i tried.
I unzip the files, set their rights and can see this app as disabled (in Browser as well on console with “occ app:list” command.
I tried to enable the app, but it doesn’t work.
In the browser i get the
Could not download app calendar_resource_management
and on console with
sudo -u www-data php -d memory_limit=512M ./occ app:enable calendar_resource_management-master
but get the response “App not found”
How can I enable this feature?
Someone an idea?
After i looked for some issued i found this:
the command
sudo -u www-data php -d memory_limit=512M ./occ app:list
listed the App “calendar_resource_management-master”.
I looked than in
/var/www/nextcloud/apps/calendar_resource_management-master/appinfo
where the ID named “calendar_resource_management”.
so i tried
sudo -u www-data php -d memory_limit=512M --define apc.enable_cli=1 ./occ app:enable calendar_resource_management
and get the same
"Could not download app calendar_resource_management"
Found the solution to activate
The Zip file creates the folfer “calendar_resource_management-master”, but it has to be “calendar_resource_management”.
The solution:
cd /var/www/nextcloud
mv app/calendar_resource_management-master app/calendar_resource_management
but how can i now use it?
