I like to give my nextcloud box a static ip address. What is the best way to do this? And can i safely do this without breaking the box. Can I edit the interfaces file? eth0 static or is there an app for this.
You’ll be fine editing the interfaces file.
Ok it worked! For people who want to know…
sudo vim /etc/network/interfaces
auto eth0
iface eth0 inet static
address 192.168.1.200
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.1
dns-nameservers 8.8.8.8 8.8.4.4
esc, type “:qw” and press enter
sudo ./occ config:system:set trusted_domains 2 --value=192.168.1.200
